Question about Shimano Cycling
My Shimano TX-31 is not lined up correctly. When I shift into 7th the chain comes off because the Derailer goes beyond the 7 sprocket. How do I adjust this? It is also causes a clicking sound when in 1 gear.
  • 843 Answers
There are two screws that limit how far the derailer travels in both directions. Yours is apparently traveling to far out, and not far enough in. See the diagram at the link below. The two screws are identified by number 3. You will need to adjust both of them. With the chain on an intermediate gear, try turning one of them them 1/4 turn, then check the result. You'll soon get it right. Good luck. If you found this useful, please vote
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/RD/EV-RD-TX31-2753B_v1_m56577569830637983.pdf
Posted on Sep 01, 2010
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
How to keep my gears from slipping
Firstly ensure the derailleur is in good condition and not bent so the chain is running perfectly in line with the sprockets. Ensure the stop screws limiting the extent of the travel of the derailleur are set correctly to prevent travel beyond the first and last sprocket.
A badly worn chain could need shortening or replacing in order to provide the correct chain tension or a loose chain could be a matter of a derailleur that hasn't seen the oil can for a while and is not tensioning the chain correctly.
If the bike has been involved in an accident the rear forks could perhaps need some adjustment so a straight edge laid alongside the main chain-wheel coincides approximately with the middle of the rear sprocket cluster.
At this stage it is also wise to ensure the gear cable is in A1 condition, smooth operating and properly oiled with no internal frayed strands causing problems.
If your gear selectors are of the modern style with detents the gear cable needs adjusting so the centre of each detent at the gear selector positions the derailleur precisely below the selected sprocket. Once this is done if everything else mentioned above is ok the gears should now operate smoothly and positively.
If adjustment doesn't work then the problem is likely to be with the basic requirements above.
Jan 26, 2015 | Cycling
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
Sep 01, 2014 | Shimano Rd TX50 Tourney Mega Range Rear...
My rear derailer needs adjusting, it slips in between gears.
As mentioned above, it could be many causes but assuming that the drivetrain is in proper working condition it is a simple matter of cable adjustment. If your derailleur has a "barrel adjuster" on it your good to go. This is usually a plastic sleeve that sits right before the cable housing enters the derailleur body. If you shift to a higher (smaller) gear & the chain doesn't follow you want to turn the adjuster the direction that you want the chain to go! In that case it would be clockwise. If you shift to a lower (bigger) gear & the chain doesn't follow, you'll turn the adjuster counter clockwise. However, newer derailleur systems like Shimano's Shadow series or Sram's derailleurs, you'll notice that there is no barrel adjuster at the derailleur end! So... you'll have to use the barrel adjuster at the shifter end. Good Luck!
Aug 03, 2013 | Cycling
Shimano tourney TX sis 1. Noise while shifting gear and in motion 2. Chain stucked up at sprockets.
This problem is best taken into a bicycle shop to have them look at it. Could be as simple as adjusting the cable tension, or as complicated as parts not in the correct location or functioning properly. The shop will be able to make a quick diagnosis once they can actually put hands to it.
Jan 02, 2011 | Cycling
My Shimano TX-31 is not lined up correctly. When I shift into 7th the chain comes off because the Derailer goes beyond the 7 sprocket. How do I adjust this? It is also causes a clicking sound when in 1...
Take a look at the diagram in this link, see the two screws identified as Number 3. http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/RD/EV-RD-TX31-2753B_v1_m56577569830637983.pdf
You need to adjust both screws, since one adjusts how far in the derailer goes, and the other adjusts how far out it goes. Start with the bike in a mid-gear and turn one of them 1/4 turn. Check the result. Proceed by trial and error. Good luck. If you found this helpful, please vote. Al K
Sep 01, 2010 | Royal Cycling
Trek 6500 Shimano deraileur adjustment issues
Derailleur adjustment takes time to master. Try this out:
First, wash your drive train out really thoroughly and use a degreaser (Simple Green works really well) and a chain brush on the derailleur and chain. Rinse it off and let it dry, then relubricate the chain (and ONLY the chain - never lubricate your derailleur). Now flip your bike onto the bars and saddle so you can crank while you shift manually. Use the middle chainring up front to adjust the rear gears. Okay, shift into your highest gear in the back and then release the derailleur cable. Use this opportunity to make certain your "H" setting is good; the derailleur's jockey wheel should be perfectly aligned over the small cog. Now manually push the derailleur to the lowest gear (while pedaling) and set the "L" so the jockey wheel is immediately outside the last cog. crank back to the high gear. Turn the barrel adjuster for the cable tension to its half-way point (figured by unscrewing it all the way and then counting revolutions as you screw it back in). Pull the cable taut and reattach it. Shift into your middle gear (or if it is an even number of gears, pick one of the two middle gears). Use the barrel adjuster to get the jockey wheel exactly over the correct cog. Pedal and shift through the gears. In each gear, back-pedal to make sure the chain is not skipping. You should be able to free-wheel without problem in every gear on a properly adjusted drive train. If the gears are requiring much adjustment on the barrel adjuster, then you may have a bent derailleur hanger. This can be straightened manually without tools if you have a good eye and patience. If it goe that far, come back and repost "bent derailleur hanger".
i hope this helps
-matthew
Oct 28, 2009 | Cycling
Cycling Logo
263 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
