Hibernation Why can?t my machine hibernate?
    Problem Solver:
  • 35 Answers
Click Start, Click Run and type "NOHIBER.TXT" and it will tell you what’s holding
things up. Most common cause is the audio driver
Posted on May 10, 2008
Hibernation partition
Make sure you have the HDD in the same state as it was on Hibernating. If it was removed after Hibernation, it will not be 'seen' by the PC. Everything that was connected during Hibernation MUST be connected again when starting the machine so the O/S can follow the route.
Nov 22, 2013 | Western Digital Computers & Internet
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
on May 28, 2010 | Computers & Internet
I can't get hp elitebook 8530p out of hibernate mode
The hibernate is one of the worst idea's that microsoft came up with, used long enough it will corrupt windows. If you can get it to come out of hibernate mode, go into power options and uncheck hibernate box and click apply. If you are unsuccessfull you will need to do a complete recovery of windows operational system.
Apr 28, 2012 | HP EliteBook 8530p Notebook
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Aug 07, 2009 | Averatec C3500 Tablet PC
How do i get laptop out of hibernation
To get the machine out of hibernation just press the power button.
Jul 01, 2009 | Toshiba Satellite Pro L300 Notebook
Dell crashes and restarts upon sleep_suspend_hibernate
I'm not a big fan of using hibernate or standby, I've seen it cause too many problems, such as the one you're having. I shut my machine down when I'm done, or let it run if I'm coming back within a reasonable amount of time. I've also seen hibernation or standby create operating system errors or glitches, and premature hard drive failure. If the machine is working properly other than hibernation/standby you should shut the hibernation off and just shut the machine down when not in use. If you're getting this error when using the power button to turn off the computer, then the operating system has glitched or is corrupt and needs to be reistalled. If you need anymore help with this let me know.
Jul 01, 2008 | Computers & Internet
I want to reactive my HIBERNATE action
Plz Check
Feb 15, 2008 | Computers & Internet
Won;t Hibernate
Sony laptops are infamous for these kinds of problems. You very likely have another Sony program running in the system tray which is trying to control all power functions in a "smart" (in other words, defective) manner, and this is conflicting with and resetting your OS's normal power settings. Try to find this program on your laptop and run it and check what it thinks it is doing. You might also have a problem with the actually writing of the hibernation file on your machine due to any number of problems (low disk space, conflicting file names, corrupted administraive priveledges for whatever program thinks it is doing the writing). I'd suggest uninstalling the SONY power management software and then using the stuff the operating system provides. It might not be good, but it at least works kind of, and consistently.
The changing status of the hibernate settings you describe suggest to me that another program is changing them to try to be "efficient".
Last resort - disable hibernate; it doesn't work very well on Sony laptops even at the best of times.
Nov 16, 2007 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
