Question about Toshiba Satellite A105 Notebook
How do i restore my laptop.the varius protection was deleted.
  • 2,229 Answers
You can do a system restore using start>programs>accessories>system tools>system restore.
If the actual files have been deleted, though, you will need to reinstall the program.
Posted on Sep 01, 2010
I have a system crash n need fix my gateway nv53a laptop ow do i do that and what do i need to do as was getting numerous virus attack n system crash on me as gateway/ac
if you have a virus in the hard drive use your security program to do a full scan and delete any virus that is found. If you do not have a security protection program (norton-kaspeshey -mcfee etc then take it to a tech shop and see if they can help
Feb 15, 2015 | Gateway Computers & Internet
What can I do to rescue data deleted by pressing "Shift+ Delete" on Windows 7?
Using Shift+Delete to remove files/folders bypasses the recycle bin which is your normal means of recovering accidentally deleted files. You can go to download.com and search for file recovery programs. Some are available that will search your hard drive and can maybe recover what you lost. It is important to do so as quickly as possible because once files are permanently deleted on the hard drive, the sectors that they occupied are no longer protected and can be overwritten by any program or file.
Dec 25, 2014 | Computers & Internet
Hi, how do I use WPS push button response on my lg mobile phone. I see where it says wps available with the varius wifi networks but don't know what to do to access them?
Wi-Fi Protected Setup (WPS) for secure wireless network set up and connections.
I think it help you a lot step by step http://kb.linksys.com/Linksys/ukp.aspx?pid=80&vw=1&articleid=17594 .
Apr 30, 2014 | Computers & Internet
Restoration problem
How often are restore points created?
Restore points are created automatically every day, and just before significant system events, such as the installation of a program or device driver. You can also create a restore point manually.
How much hard disk space does System Restore require?
To store restore points, you need at least 300 megabytes (MB) of free space on each hard disk that has System Protection turned on. System Restore might use up to 15 percent of the space on each disk. As the amount of space fills up with restore points, System Restore will delete older restore points to make room for new ones.
How long are restore points saved?
Restore points are saved until the hard disk space System Restore reserves is filled up. As new restore points are created, old ones are deleted. If you turn off System Protection (the feature that creates restore points) on a disk, all restore points are deleted from that disk. When you turn System Protection back on, new restore points are created.
The restore point is a built in utility by microsoft, you can't have the option to configure the settings!!!
Jul 15, 2010 | Microsoft Windows XP Professional
Not enough space on friends laptop
First you need to disable system restore on the drive to reclaim the missing space. To do this, you can do the following:
1. Go to Start > Control Panel > System
2. In System > Click on System Protection at the left side
3. In the System Protection Window > go to the System Protection Tab > then uncheck C: then hit Apply then OK
After disabling system restore, run disk clean up:
1. Go to Start > Computer > Right-click on C: > Disk Cleanup - make sure to check all of the files to be deleted to clear as much space as possible
2. After initially running Disk Cleanup you will now be able to see the More Options tab in the Disk Cleanup window > go to this tab then cleanup the System Restore and Shadow Copies to remove them completely
3. Enable the System Restore from the System Protection tab in System.
4. Resize the maximum amount of Shadow Copies that can be saved on the system, this will lock the System Restore feature from saving more than allocated amount. Run Command Prompt as administrator (go to Start > Programs > Accesories > then right-click on Command Prompt then Run as Administrator)
Set the maximum to whatever amount you feel is necessary. Setting it to 1GB should be more than enough for System Restore to create at least two restore points. Type the command: vssadmin resize shadowstorage /on=c: /for=c: /maxsize=1gb
5. Once this is done you should have reclaimed at least 30 to 40% of the missing space. Once the System Restore has been reenabled it will automatically create the restore points so there will be no need to manually create one.
Mar 22, 2010 | Compaq Presario Notebook
Error 0x8007045D - cannot transfer data - I/O device error
try deleting all restore points before attempting a system full backup. the system is protecting this area on the drive from being copied deleting the restorepoints will allow backup remember to re enable system restore after, do this by disabling system restore temporaraly while preforming backups.
Dec 22, 2009 | Televison & Video
Deleted user account
See if System Restore is turned on. Right click on MY COMPUTER, choose PROPERTIES. Click on SYSTEM PROTECTION. Then SYSTEM RESTORE. You will have to choose a restore point (these are shown as darker colors in the calender ). Just choose the nearest date and restore.You will not cause any harm.
Sep 22, 2009 | Acer Aspire One AOA110-1588 Notebook
I have lost my enternet connection,Audio,printer, and varius other programs. I have the three disc for restore of T2742, but can't seem to get them to work. I would like to try a complete restore.
Your information is not enough, are you trying to install your restore DVD for your operating system. Give me some info., so taht i can help you.
Jul 24, 2009 | Office Equipment & Supplies
My pc has a problem
You didn't mention what os you are using xp or vista. What software are you talking about that it came with? also Norton Anti virus is known to cause problems with windows restore. So taking a wild guess check out these steps
Many users have found that Norton 2006 and later, has been responsible for this error message. It seems there is a security feature in place that prevents outside programs from making system changes that would change Norton's files. To work around this issue, follow these instructions:
<>Temporarily shut down Norton:
  1. Start Norton
  2. Select Options>> Norton Anti-Virus
  3. Select Miscellaneous from the right pane
  4. Scroll down the right pane and locate "How to protect my product"
  5. Uncheck the box titled: Turn protection on for my Symantec product
  6. Click OK
<>Run System Restore:
  1. Go to Start>> All Programs>> Accessories>> System Tools>> System Restore.
  2. Select the option: Restore my computer to an earlier time.
  3. Select a restore point to restore back to.
  4. Click OK
The restore operation will now start. Restart Windows when completed.
<>Turn Norton back on:
  1. Start Norton
  5. Check the box titled: Turn protection on for my Symantec product
  6. Click OK
If you do not have Norton installed on your system and you receive the subject message, your Restore Points may have become corrupt. You will need to delete all previous restore points and create a new one. Here's how:
Note: Using this method will remove any possibilities of restoring your system to a previous time. You will need to find a solution to your original problem manually.
  2. Select System Restore Settings from the left
  3. Place a checkmark in the checkbox titled: "Turn Off System Restore". By turning off system restore, you are deleting ALL restore points.
  4. Go back to System Restore and select the option "Create a Restore Point".
System Restore should function normally at this point.
Jul 03, 2009 | Sony VAIO VGN-CR420E/W Laptop
Cannot turn protected mode on or do system restore
This will delete everything and set computer back to factory. Save all pictures, music, etc.
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
May 09, 2009 | Toshiba Satellite Pro L350-S1701 Notebook
Toshiba Satellite A105 Notebook Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
