Question about Acer Aspire One PC Notebook
My computer won´t charge, The battery held little charge and now the computer won´t turn on at all. The charger had to be wiggled to get the charging light on, is this a charger, battery or laptop problem?
  • 398 Answers
Likely to be a charger issue. You can pick up a new generic charger from your local supermarket for a few pounds
Posted on Sep 04, 2010
Razor electric scooter e 300 battery charges but won't run
first check to ensure the batter has held the charge you put into it. Just plugging the charger in does not mean the battery is holding the charge. If the battery is bad, it will drain as fast as you put it in. if the batter holds a charge, should be able to disconnect the charger and battery will show charge. if so, you have a bad connection or motor.
Jun 29, 2013 | Motorcycles
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
Phone wont charge so will not turn on
Have you tried more than one power outlet? It could be the power outlet you're trying to use isn't functioning. If it won't charge on a different outlet, the issue is either the charger you're using or the phone itself. Try wiggling the charger around while plugged in to the phone, see if that will charge it at all. You should also trying getting a different charger and see if that will work. If not, you may just need to replace the battery/phone.
Aug 14, 2011 | Ericsson Cell Phones
Ambiedabambie@aol.commy phone won't charge
Charger connector to phone worn out, wiggle it around to see if it starts charging.
Not plugged into a live outlet.
Charger broken, replace.
Phone battery failed, replace.
Call or visit your carrier and ask for help.
Jun 16, 2011 | Cell Phones
My little buddy won't turn on, it's charged, plugged into computer. green light won't come on at all. I held the power button on for 10 -15 sec with no response.
I have 2 of these devices. Try using a cellular phone charger with the same plug at the end and plug it in. I have waited 5-10 minutes after doing this and they have come back to life and turn on. Maybe it will work for you.
Lewis
May 14, 2011 | Insignia GPS
My computer no longer charges. I replaced the charger and for a little while the new charger was working. But now the new charger will be in the charger portal and the computer does not charge at all once...
this problem comes from a bad Battery.
you told:"I replaced the charger and for a little while the new charger was working"
it means that the battery is damaged and only because of a new charger, charged for a little time.
so change the battery.
Jan 17, 2011 | HP Mini 1035NR Notebook
BATTERY WON´T CHARGE ON DELL C600
It is possible the battery where the contacts from the laptop fit into or the gold colored contacts themselves need to be repaired. Worst case, the spill short circuited the contacts on the board, in which case you will have to replace the board. I would suggest really cleaning the gold contacts on the laptop and the small slots on the battery itself with a Q-tip with a little bit of rubbing alcohol on it. Please make sure both areas are totally dry before reassembling the battery.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell Latitude C610/C600 Notebook
Battery won't charge on casio ex-z77 exilim
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
Mar 26, 2009 | Casio Exilim EX-Z77 Digital Camera
Acer Aspire One  PC Notebook Logo
279 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
