Question about Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
User Profile Service Service failed the logon ( I logged in correctly ) and I cannot log on on the entry point of the system my name is correctly displayed never happened before
  • 300 Answers
SOURCE: Dell Inspiron 1420 - says user profile cannot be loaded
Try this, it should work and it really is quite easy to follow -
1. Boot up in Safe Mode. To do this, hit the F8 key while the computer is
booting, and then scroll down to the "Safe Mode" option and press enter. On
my computer the user account icon appeared, but bigger than normal, and I
clicked it and it loaded my desktop in safe mode. It came up with an error
bubble saying that my user account hadn't loaded properly, but I just ignored
this.
2. Click the Start Button and in the white "Start Search" space at the
bottom type "regedit" (without the quotation marks). This will open the
registry editor.
3. In the left-hand pane, navigate by clicking the little triangles next to
the following folders:
HKEY_LOCAL_MACHINE
SOFTWARE
Microsoft
Windows NT
CurrentVersion
ProfileList
You should now have a list of folders all starting with S-1-5- and then a
number.
(You might need to drag the divider between the 2 panes of the window across
so you can read the whole folder name)
Look at the end of each name and you should see one with .bak at the end of
it, and there will be another one above it with exactly the same name but
without .bak at the end.
The one that's got .bak at the end is your old User Profile that Vista has
now made into a backup, and the one without .bak after it is the new empty
User Profile that Vista has created.
Just to check that this is the case, have a look in the right-hand pane for
each of the 2 folders and look at what's written after "ProfileImagePath".
For the folder with .bak at the end it should say C:\Users\ and then your
usual User Account name, and for the one that doesn't have .bak at the end it
should say C:\Users\TEMP.
What you need to do now is to rename the folders in the left-hand pane so
that the one with .bak at the end changes back to being the one containing
your proper User Profile and the new one without .bak at the end becomes the
backup. Do do this follow the next step:
4. Right click on the folder with .bak at the end and then click "rename",
and just change the ".bak" part to ".bk" - i.e. just remove the "a" from the
middle - (this is just to allow you to change the other one to have .bak at
the end). Press enter or click on some blank part of the screen for the
change to take effect.
Then, right click the one that doesn't have .bak at the end and click
"rename". Remove the .bak from the end and press enter or click anywhere on
some blank part of the screen to accept the change.
Then, right click on the one that now has .bk at the end, choose "rename"
and add the "a" back into the middle, so it now has .bak at the end. Press
enter or click on blank park of screen to accept the change.
Close the regedit window.
5. Click the Start Button and then "Restart".
It should work now, otherwise see link below -
http://support.microsoft.com/kb/947242
Posted on May 21, 2008
PauldLucky
  • 268 Answers
SOURCE: User profile cannot be loaded
The instructiond were clearly givn in this link with images :
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
STEP ONE:
Logon to the Computer
NOTE : Go down the list here until you find a option that will work for you.
1. Logon to another Administrator account.
NOTE: If you do not have another Administrator account, then proceed to step 2.
A) Go to OPTION ONE or OPTION TWO.
2. Boot into Safe Mode.
NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. See: How to Start Vista in Safe Mode
A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C.
NOTE: See: How to Enable or Disable the Real Built-in Administrator Account in Vista
B) Logoff of Safe Mode, and then logon to the built-in Administrator account to logon with it in Safe Mode.
C) Go to OPTION ONE or OPTION TWO.
OPTION ONE:
Fix the User Account Profile
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
B) Add .bk to the end of the numbers. (See screenshot below)
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click OK. (See screenshot below)
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
OPTION TWO:
Delete the User Account Profle
NOTE You can do this option if you do not care about losing the user account and the contents in the user folders.
1. Delete the User account profile that this error is for.
NOTE: See: How to Delete a User Account in Vista
2. Open the Start menu.
3. In the white line (Start Search) area, type regedit and press Enter.
4. If prompted, click on Continue.
5. In regedit, go to: (See screenshot below step 7)
6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it.
NOTE: It may have .bak at the end of it.
A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above.
B) Repeat step 6 until you find the one that you deleted in step 1 above.
NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9.
7. To Backup the Registry SID Key -
WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below.
A) Right click on the SID key, and click Export.
B) Type in a name and save the REG file to a safe location.
NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click Merge.
C) Continue on to step 8.
8. To Delete the Registry SID Key -
A) Right click on the SID key, and click Delete. (See screenshot above)
B) Click Yes to confirm deletion. (See screenshot below)
9. Close regedit.
10. Now, just create a new normal Administrator account.
NOTE: See: How to Create a New User Account in Vista
11. Restart the computer, and logon to your new account.
Good Luck.
Live, Love, Laugh.
Posted on Sep 11, 2008
SOURCE: dell inspiron 1525 notebook
Posted on Oct 06, 2008
  • 2219 Answers
SOURCE: my acer when I log on says user profile service
use F8 and go into sfae mode, this will load a default profile and will allow you to add a new user (to create a new profile).
Then you can logon in using the new profile.
Posted on Apr 11, 2010
  • 244 Answers
SOURCE: user profile service failed the logon, user
Restart, and press the F8 key.
This way you'll access the SAFE MODE.
Click on the ADMINISTRATOR account.
Usually there will be no password, so you can get to the Desktop, and erase your user password.
Then simply reboot and let it complete the cycle.
Don't forget to rate this answer if it helps
Posted on Sep 17, 2010
Unable to log on IdeaPad Z570 Model Name 20095
If you are not logged on, you cannot change the password. What happened before you had a problem?
Mar 23, 2016 | Lenovo IdeaPad Computers & Internet
How do I unlock my laptop? The message is "the user profile service failed the logon" "user profile cannot be loaded"
louise,
click the link below for resolving the error message you are getting logging into your computer.
you receive a "the user profile service failed the logon" error message
https://support.microsoft.com/kb/947215/en-us
thank you,
dell-jesse l
dell social media and communities
Jan 21, 2015 | Dell Computers & Internet
Asus k53u accepts password then comes up the user profile service service failed the logon user profile cannot be loaded How can I get round tis problem ?
Start in Safe Mode and then do a system restore back to a date when it was ok. If that fixes it, immediately create a new restore point and name it Profile OK. (Just in case you get it again) This fault has been occurring for months now and usually after an MS critical update! Good backup strategy is paramount.
Sep 04, 2014 | ASUS K53UA1 Notebook
Won't log in, says "the User Profile Service service failed the logon. User Profile cannot be loaded."
This is a simple fix that can be done in a few minutes or less. It is a problem with either an update from MSFT that had gone awry or an attack from a virus... Anyhow the steps to take are relatively simple just follow along.
1 - go to this site and it will walk you through step by step
You receive The User Profile Service failed the logon error message *make sure to choose option 1
Apr 12, 2014 | Computers & Internet
Dell Vostro 3500 running Windows 7. Trying to log into the admin (only) account and get the message: The User Profile Service service failed the logon. User profile cannot be loaded. No Recovery Media was...
Please check following link from Mocrosoft knowledge base:
Error message: "The User Profile Service failed the logon. User profile cannot be loaded", when logging on to Windows 7 or Windows Vista
http://support.microsoft.com/kb/947215
PS: If it helps then please click on thumbs up.If you need more help then please let me know.
Sep 20, 2011 | Computers & Internet
When i open my computer theres an error the user profile service failed to logon user profile cannot be loaded
Logon in safe mode.
  • Restart your computer and log into safe mode: As your computer is rebooting, press F8 Repeatedly after your POST screen.
  • Choose safe mode with networking
  • Open internet explorer and copy and paste this site into the address bar:
http://www.thewindowsclub.com/fix-the-user-profile-service-failed-the-logon-user-profile-cannot-be-loaded
  • Click on Microsoft Fixit.
If this resolves your issue, 4 thumbs would be appreciated.
Sep 16, 2010 | Computers & Internet
I have a eeePC 1005HA with a Windows 7 I can't log on. I get the user Profile Service service failed logon. User Profile cannot be loaded. How do I fix this?
You need ot edit the Registry for the same...
Log on to Safe mode >>> Click Start >> Type Regedit in the Start Search >> Open Registry Editor..
Go to the following entry:
HKEY_LOCAL_MACHINE\Software\ microsft\Windows NT\CurrentVersion\Profile List
There you will find the following information:
On the ".BAK" file you will find an entry with ProfileImagePath with the name of the user.
Delete the repeated entry that does not contain ".BAK"
Right click on the other entry and select Rename. Delete the extension .BAK for the original entry.
Exit Regedit
Restart computer.
Dec 16, 2009 | Dell Inspiron 1521 Notebook
Cannot log on to laptop
What is your OS ?? If it is windows xp and you didnt setup admin password when your sysrem was instaled you can try restart your laptop, When will start rebooting wait till you see second boot screen and start pressing F8 when you will see emergancy menu click to save mode, Log on as Admin (not your name) and when system willl started go to: control panel,user accounts,logon as admin,go to your profile(account with your name) and press remove password. then restart your computer. Your password will be gone.
Dec 27, 2008 | Computers & Internet
Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
223 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
