Question about Refrigerators
Not keeping anything cold,or frozen. - Refrigerators
  • 944 Answers
Due to various reasons this problem could occur:
1)Check the temperature setting.
Set it to max and min and check for any changes you can see in the system.
2)The compressor vents cold air into the freezer. Occasionally the vent can become clogged with ice, food or other debris. Locate the vent and clear it. To remove ice, use a hair dryer set to "low". Using the high setting may cause damage to the components or interior of the refrigerator.
3)Test the temperature control
With the ohm meter you can test it.If it does not show any reading this is the defective one you have to relplace this soon.
4)First and simplest thing is to make sure your condenser coils on the back of the fridge usually, are clean and have adequate air circulation. If you pull the fridge away from the wall you can just brush them off or use the brush on your vacuum.
5)Check for a clogged drain tube if it is clogged remove the clog.
6)Test the evaporator fan.The evaporator fan circulates air over the refrigeration
coils. The coils absorb heat and the chilled air is then circulated. If the fan does not operate, the freezer will not cool properly. The fan motor may have failed, but check first that something is not simply blocking the fan blade.
7)Defrost timer:Usually the defrost timer could solve this issue.It may be located below or back of the refrigerator.Some times it may be located in the side to for side refrigerator.Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 30-35 minutes.Then there is no problem with Defrost timer.
8)Heater and defrost thermostat is located behind the back wall of the freezer section.This only controls the Heat.After the Defrost timer stops it makes the system warm.
Defrost thermostat could be defective.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
My freezer works but my refrigerator part is not cold
The is normally a duct between fridge and freezer which can over ice can take 3or 4 days to defrost with both doors open and unplugged.
Jan 14, 2014 | Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Deep Freeze not freezing
this could be from a faulty temp controller however my best! bet is it's low on froen due to a high pressure leak
Jan 17, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
Fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Aug 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer freezes up and don't know if there is a reset
sounds like the condenser is bad, feel the copper coils they should be cold and the condenser should be hot/
May 20, 2009 | Frigidaire Gallery GLHT214TJ Top Freezer...
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Compressor runs for 5sec.
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Food is only frozen on bottom shelf
dkburing,
You said, the freezer is only keeping the food frozen on the botton of the freezee. It is cold, but only like a refrigerator.
We need more info,
What is tour brand,model number and the year or age of the fridge.
Waiting for your reply
Huuum
Oct 09, 2008 | Freezers
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
