Question about Bryant 463AAC008BA Air Conditioner
Do bryant condensing units have a reset button? We can't get the unit to kick on. All power is correct and fan starts inside, but can't get condensing unit to kick on.
  • 107 Answers
Most Bryant units do not have a reset button but could have a low pressure or high pressure switch for a safety to protect the compressor. Verify power from the thermostat to the contactor by following the thermostat wires all the way to contactor inside of electrical compartment... TURN POWER OFF BEFORE OPENING.... If power is to contactor and contactor is pulled in then you would need to look at the capacitor of which is a canister about 6 inshes tall with wire terminals on top.. this part should be flat on the top and if it is rounded then thats your problem.. if not then contact a local company to troubleshoot and make necessary repairs.
Posted on Sep 01, 2010
Bryant plus 90
try replacing the run capacitor
Sep 03, 2013 | Heating & Cooling
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
My fan is nto blowing on my outside unit. i hear a light hum coming from the unit.
Sounds like the contactor is pulled in, but no power to the condenser fan motor. Check power to motor (through the contactor & check the capacitor.
Jul 11, 2011 | Bryant 463AAC008BA Air Conditioner
Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Jul 09, 2010 | Fedders C36ACD1VF Split System Air...
Condenser the compressor vibrates bad and then it shuts down code on board says high thermal cutoff
Hi, what is happening is the unit is shutting off on high head pressure from the sound of it. Bryant units are top of the line! What you need to do is shut the main power off to unit. I dont no if you have a split system 2-part with a indoor unit and outdoor unit or a package unit all in one. It really makes no difference. Go to the outdoor coil, which is the condenser coil. Take a good water hose and wash this coil very good all around and inside where the fan motor is. These units are made for outdoor use but don't spray directly on the controls. Be careful not to mash the fins with to much pressure.If the fan motor outside is running up to a good speed, this will take care of the high head pressure, I know for a fact. Let me know the out come. If by some reason it does not cure this, we will go into it further. I will be waiting to hear from you.
Sincerely,
Shastalaker7
Jun 03, 2010 | Bryant 463AAC008BA Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Condenser unit will not come on
Replace the starter capacitor.
Apr 27, 2009 | Bryant Heating & Cooling
Heating & Cooling Logo
805 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
