Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Excessive motor noise. Trying to find a diagram of where the filter plate is? Can you help?
  • Fisher and P... Master
  • 3,247 Answers
Looks like you do not have the user manual for this dishwasher.
Refer this site.
You can easily take the motor rotor out for checking it. It could be just a simple thing as a hard food waste item sitting in the cavity. (a bone piece or seed). Go to page 21 of manual and remove the filter plate. The rotor is attached to the impeller. Get it out and inspect. Also check the channel between the drain sump and rotor cavity. Use a thin rigid wire to clean it.
A replacement rotor can be got from this place if you are in US.
Please rate the solution if you found it useful.
Posted on Sep 03, 2010
My 12 yrs old house has now got excessive clonking noise coming from the internal pipe system-seems to occur every 20 mins or so-even I believe caused the fracturing of the backing plate where clamp...
Normally clonking noises are caused by loose pipework.
As the valve closes the inertia in the water bangs the pipe against the wall.
For instance in heater radiator systems it can also cause a continuous banning noise when water under pressure is pumped through it, usually in sync with the rotation of the pump motor.
Mar 13, 2015 | Home
Excessive noise and smell from dyson dc19t2
It is possible the filter is dirty and restricts air flow which heats the motor due to excess load. The smell could be from overheated motor. Clean the filter if not done recently.
http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc19T2_uk_manual_060710%20pdf.pdf
Sep 02, 2014 | Vacuums
1998 land rover discovery may have loose or broken flex plate. How to tell?
excessive noise from lower bellhousing. remove four torque converter bolts and start and run motor....if noise change then maybe flexplate
Sep 06, 2013 | 1998 Land Rover Discovery
Reinstalling beater bar... making a noise like its not in the correct slot.
Getting the sole plate back on correctly and the beater brush in the correct slot should help. The clucth is engaging and keeping the motor from overheating is the noise you are hearing.
bearings in the brushroll might be siezing. If you start snapping belts, change the brushroll. the roller brush that most likely needs to be cleaned,clean the hair from the brush and under the belt and make sure the bar is positioned in the vacuum properly and turns easily. Your problem could be the clutch unit what has probably happened is either the clutch plates are warn, or the 3 balls in the clutch have warn a large grove in there fixing plate or the plastic hub that the brush roller to clutch belts runs on has melted this hub melting is the most common of all clutch faults.
There are no spares available for repairing the clutch other than the motor to clutch belt & the clutch to brush belt. Here is a diagram to help you
Nov 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Our laserjet 4250n printer is making a awful noise when we try to print. Can you please help?
This series of printer has an inherent fault with what they call the Fuser Swing Plate. It's a small metal plate that contains a couple of cogs, one of which drives the fuser assembly. HP found that the fuser drive cog on his plate encountered excessive wear and would then cause a sometimes, quite loud whirring noise from the back of the printer.The only way to get around this is to have another, new, updated Fuser Swing Plate fitted to the printer.
Oct 08, 2009 | HP LaserJet 4250n Printer
Printing mechanism failed
The swing plate assembly needs to be replaced by an HP technician
Mar 04, 2009 | HP LaserJet 4250dtn Printer
Top drawer of dishwasher has a loud pump noise while running
Look for burrs on the botom impeller of the rotor. it requires no tools to check this. Take the wash arm and filter plate off, now rotate the motor rotor's base counter-clockwise and pull it out. Inspect the greay impeller closely for any nicks or burrs. If any are present, the impeller will make a LOT of noise. If it needs to be replaced, you can find them at fisher paykel parts, here is a link to the part you will need:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=9
Nov 23, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Hotpoint OTR Microwave - Carousel Motor Noise
You should be able to access the turntable motor if you remove the left side filter under the microwave. Disconnect the power, remove the left filter and look up inside that area, the motor may have a cover or plate over it, if so remove it, the motor will be held in with 2 screws (usually) and there will be 2 quick disconnect wires attached to it. If you cannot get to it that way you may have to remove the bottom of the microwave (underneath), should be only 3 to 5 screws holding it in place, the side to the wall will be hinged, once you pull the screws just let it hang or swing down away from you. Then follow the above directions. Make sure that you are getting the correct motor, there are two types, one is a square shaft (WB26X10037) and the other is a "D" shaped shaft (WB26X10038).
Jan 21, 2008 | Hotpoint RVM1635 Microwave Oven
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
55 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
