Question about NEC MobilePro 800
NEC MobilePro? 800 - How to find and install drivers? Established MS Windows CE Handheld PC Editon ver.3.0: Core System ver. 2.11 When inserting a PC Card slot LAN PC Card 3Com 3C589D For a short time enabled LED PC Card 3Com and then turns off. How to find and install drivers: 1. for LAN PC Card and Wireless PC Card 2. for USB Wireless Adapter and USB Bluetooth Adapter When you connect a new device dialog box appears: Unidentified USB (PC Card) Device: Enter the name of the driver for this USB (PC Card) Device: Driver Name: Small Window
Windows ce and memory cards
MobliePro 780 can use up to 32mb of memory and not 16mb but but you can't get any higher cause its limited by Windows CE Memory Map. If nec will offer an upgrade for windows CE3 or higher problem could be solved.
Sep 19, 2005 | NEC MobilePro 780 Pocket PC
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800:ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800: ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
Windows ce networking
Well your going to have to check whether your device has inbuilt wireless capability (refer to manual). If it doesnt there are various expansion slot solutions like SD and Compact flash wireless cards.
Sep 15, 2005 | NEC MobilePro 780 Pocket PC
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
MobilePro 900 turn on during the night and not shut back off
Devices running Windows CE 3.0 turn on at midnight to search for appointments for the coming day. Reminders are set and the Today view is updated with the day's events. The device is supposed to turn off after three minutes of inactivity. If a program is running the unit may not turn off because there is activity. The following applications are known to cause problems: * Windows Media player for Pocket PC. * Active Sync * Wireless LAN adaptors NEC has developed a registry patch that has been tested on the following LAN cards. Device Vendor Driver Cisco Aironet 340 Cisco 2.30.11 Cisco Aironet 350 Cisco 2.30.11 Linksys WPC11 Ver 3 Linksys 1.07.29 Orinoco Orinoco 1.02 3CRWE737A 3 Com 2.2.5.0 LA4137 Wireless Network Symbol N/A For additional information see Microsoft Knowledge Base Article – 263719 Click here to download the Power Management update utility. Installation procedure. Note: Anytime a “hard reset” is performed on the MobilePro 900 the Power Management update utility needs to be re-applied. 1. Download the Power Management update utility to local system. 2. Copy the Pwr_Mgt.exe file to the MobilePro 900 desktop. 3. Double tap the NEC Icon. 4. Click OK. 5. With power on momentary depress the “soft reset” on the bottom using the stylus. 6. Delete the NEC Icon on the desktop.
Sep 14, 2005 | NEC MobilePro 900 Handheld
NEC MobilePro 800 Logo
109 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
