Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
Jenn aire just self cleaned my oven getting F2 HOW do i make it stop.
  • Anonymous Jul 30, 2008
    shut off circuit breaker - still doesn't work
  • 117 Answers
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Posted on May 10, 2008
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
I cannot get my Jenn Air oven to self clean. The fan comes on but does not clean--only cool air.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 11, 2010 | Ovens
F2 code on Jenn air double oven
One website said its a relay board problem. Years ago I replaced the entire electronic board and did it myself and I am not overly good at such stuff, so it can be done if you find the correct part. I am having that problem and am searching for a relay board or whatever it is.
Dec 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jenn-Air self cleaning wall ovens model W2451
We have a W245 self cleaning oven and the woven gasket is falling apart, can we purchase a new one to replace it?
Jan 16, 2008 | Jenn-Air JJW8527C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
463 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
