Question about Black & Decker SV1000-4 SteamBuster Vacuum
What is the product number for the gasket inside the Black & Decker SteamBuster Vacuum? It's a model SV1000.
  • 436 Answers
Posted on Apr 11, 2011
Everything is working as it should, but it doesn't steam
Minerals in the water may have solidified and clogged it. The vinegar is an acid which can help to dissolve and flush and rinse out the minerals.
Sep 01, 2017 | Black & Decker SV1000-4 SteamBuster Vacuum
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Feb 20, 2008 | Black & Decker SV1000-4 SteamBuster Vacuum
Black & decker steam buster
Step 1 - fill the rear tank with water. Clip the tank onto the back of the unit.
Step 2 - plug the unit into the wall.
Step 3 - move the switch to "steam". You should hear the unit 'ticking' at the rate of about 120 clicks a minute (2 clicks a second). The clicking should be "kind of" loud until the water makes its way into the pump.
The clicking will get quieter as the water moves through the pump and into the heater. The book says that you should start getting steam in a couple of seconds. My experience is that you don't get a good head of steam up until the unit has been going for about 20 seconds.
Another recommendation: don't use "Spray" until the steam is really rolling out of the unit. It just overpowers the heater and slows your steam production.
Step 4 - Steam the spot you want steamed. If you want to soak the spot, use "Spray". Most of the really good cleaning power of the unit is through the steam, so use that more than spray.
Step 5 - Switch to Vacuum and **** up the moisture from the steaming.
Repeat Steps 4 and 5 until you're happy with the cleaning.
Step 6 - Empty the front tank, rinse it out. Empty the rear tank; you probably won't get all of the water out, but that's not a problem. If you use tap water, put in a couple of teaspoons of vinegar and let the unit run until you've sucked the last of the water/vinegar solution out of the tank. If you use distilled water in the rear tank, you might be able to skip this step.
Step 6 is intended to reduce the amount of lime scale that will build up in the pump over time. You should probably avoid stronger chemicals, since they are going to sit in the pump until you use the unit next, and the first few seconds of steam on the next use will have whatever chemicals you are using.
Aug 31, 2007 | Black & Decker SV1000-4 SteamBuster Vacuum
You can download the manual from the link below: http://www.dewaltservicenet.com/ServiceNet/Logon.asp You will need to register but it's free. As you know there's not much to the spray function but you should hear a pump running when you push the switch. You may need to clean the dirt bowl & filter for better results this is described in the manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 13, 2007 | Black & Decker SV1000-4 SteamBuster Vacuum
Black & Decker SV1000-4 SteamBuster Vacuum Logo
142 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
