Picture blurs into distorted colors - Televison & Video
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with the manufacturers name and model no# of the unit so that I can further assist you.
Thanks
Rylee
Posted on Sep 01, 2010
  • Rylee Smith
    Rylee Smith Sep 01, 2010
    From what you have described it seems that the inverter board is fine and is also getting 20vdc from the power supply board. So it is either the T-con board in the unit has gone bad and/or it is not getting the required 12vdc from the power supply unit. If you have knowledge of internal circuitry of the unit then you can open the back of the unit and check the T-con board which is the last board before the LCD panel. Usually it is available with the LCD Panel. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Hoizontal and vertical lines on screen---color distorted
Can you give me the model of the camera? Also how long have you owned the camera? After you take the picture and download it to the computer does the picture look ok? Once I have more information I can assist you further.
Thank you,
Lee
Sep 05, 2010 | Panasonic Cameras
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Picture on Samsung LCD LNT5271F is blurred sometimes, lines, color distortion, double images, then goes away and will come back.
Try reseating the LVDS cable.It runs from the main signal board to the T-con board at the top of the panel.
Dec 01, 2009 | Samsung LN-T5271F 52 in. LCD Television
Picture is blurred, distorted color and panoramic view. How to reset it.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
I was watching my HCL4715W TV and the picture
It sounds like one of the convergence Ic chips is bad---you will need to locate and replace both of them and look for any damaged parts around them; there usually are two pico fuses in this area, one for each IC. The fuses do not look like glass fuses--they usually are green or orange in color and will have the amperage marked on them and on the top of the circuit board.
Aug 09, 2009 | Samsung HCL4715W 47" Rear Projection...
White balance and blur underwater
You are not doing anything wrong with your white balance, white balance is very difficult under water, and you should be careful, because your mask might be tinted a certain color, I reccommend leving you white balance normal, then adjusting in photoshop, take a white object down there and hold it over a non important part of the picture, to help with adjusting in photoshop, then crop the object out of the final image. Focusing underwater is difficut as well, as dater distorts light, there is nothing that you can do to keep the water from distorting the light, but if you go to apeture priorities, you can increase your apeture to between f7.2 and f11 to reduce blur (to keep the picture from being too dark and the shutter from being too slow, you can increade your ISO)
Jul 28, 2009 | Fuji FinePix F100fd Digital Camera
Bottom left corner of my toshiba 65h83 is blurred with color distortion mainly magenta and green. Distortion Is a half moon shape with the open end facing the edge of the set. Total distortion takes up...
Have you tried the "Magic Focus" Button/Option in the Menu Setup Screen? If you have and it still is there, You Have a Burned out Color Tube. It is Cheaper to Throw it away and Buy a New one.
Good Luck..
May 12, 2009 | Toshiba 42H81 42" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Dropped camera, took awful pictures for a while
Possibly who can tell - probably a connector came loose and you smacked it back Lucky old you.
Sep 07, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Green blur bot-R and up-L corner and no audio
If a standard TV has color splotches in 1 or 2 corners of the screen, it is possible that a large magnet, such as a large speaker, is or was near the set and has magnetized the picture tube. The set has a built-in degaussing coil but it is small and will only demagnetize small magnetic fields. Make sure there are no magnets near the set and if the colors are still off, have the picture tube demagnetized with a strong portable demagnetizer. As for the audio, when there are audio output jacks on the back of the set then there is usually an option to turn the speakers off. Some sets have a switch somewhere and some sets have a setting in the audio page of the on-screen menu. Look for a switch or go into the menu, navigate to the audio page and look for a speaker setting (ON / OFF) and make sure the speakers are set to ON.
Aug 28, 2007 | Konka K2386U 23" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
