Question about Sony PlayStation Portable (PSP) Console
Psp My UMD is not working in my psp
Dump your PSP for good... heheheh or don't paly PSP because PSP is not for NEWBIES like you.... ********... hahahaha
Posted on May 11, 2008
  • 55 Answers
SOURCE: Sony PSP wont play umd
Go and return this to Sony if it is under warranty or go to a nearby repair shop to fix it. I believe the diode has been damaged from the qtip being used. Those lasers are delicate things.
Posted on Aug 24, 2007
minteker
  • 52 Answers
SOURCE: NEED HELP ON PSP CONNECTION ON TV
Hi. From what I have read, you need a progressive scan TV (basically an HDTV), to be able to view games on your TV using the psp-2000 with cable.
The other alternative, only one I know of is:
http://www.playerschoicevideogames.com/pd_psp.cfm
Posted on Mar 19, 2008
  • 21 Answers
SOURCE: psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Posted on Jan 10, 2009
micromatikal
  • 2777 Answers
SOURCE: PSP not reading UMD motor not spinning
This unfortunately is a fairly common problem with PSPs. I would recommend giving Sony a call, there's a good chance it's still under warranty. Their number is 1-800-345-SONY (7669)
Posted on Jul 08, 2009
SOURCE: psp always read from umd,making it hang
Hi! I incounter this problem as well even without UMD its still loading and even I disable auto-start UMD still same so I tried reflashing the software but still same problem so I discover the solution before you turn-on your PSP try to open your UMD cover you'll see it will load faster then close again the cover once you see the battery and clock icon... The problem that causing this is the switch inside the UMD possible its stock-up or spoiled already!
Posted on Dec 01, 2009
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
Psp always read from umd,making it hang
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
Common symptoms
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Upgrade and using non UMD on PSP
For non UMD files like video or music to work on your psp you need a media manager designed to work on the psp which you can get anywhere they sell peripherals for the system, but if you want to get DVDs or something on the psp it won't work. As for upgrading just buy a recent game, or hit the internet upgrade button on the menu while connected to a WIFI access point and it will do it automatically.
Jun 10, 2008 | Sony PlayStation Portable (PSP) Console
PSP Problem
I dont know how technical savvy you are but there are several DIY guides on the internet to replace the UMD drive which often fails on the PSP.
Check out this website for a complete tutorial.
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
you can find hte UMD parts on ebay usually as well
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=psp+umd+drive&category0=
If not type in google psp repair.. there are plenty of place that do repairs.
Apr 29, 2008 | Sony PlayStation Portable (PSP) Console
Psp having problem reading umd.
Hi Goodhelper,
Check the UMD for any kind of foriegn obstruction. You can use a pencil with an eraser to psin the UMD manually. Do this to check to be sure the UMD is not scrubbing or sticking inside its case. Try a different UMD to see if its the UMD or the UMD drive inside your PSP.
If you find it is the PSP. Services listed with Fixya can repair your PSP. Click on "REpair Directory" at the bottom of this screen. In the next screen, Click on "Video Game Consoles". Pick a good PSP repair service.
Nov 23, 2007 | Sony PlayStation Portable (PSP) Console
Psp-lazer ain't reading the games
This link should help.
  • Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
  • Try playing the UMD on a different PSP system. If the UMD plays, the original PSP system may be the problem. If the UMD does not play, the problem may be isolated to the UMD itself.
  • Try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Make sure the exposed UMD surface and plastic casing is not damaged[2]. Do not use if plastic casing is cracked, collapsed, or if foreign materials have entered inside the UMD enclosure.
Nov 10, 2007 | Sony PlayStation Portable (PSP) Console
Where is the UMD?
UMD is Universal Media Disc, its a small disc are used for PSP.  press the "eject" button on the top to open the disc tray. Usually the problem its not from the UMD, but from the console.
The first check the version you are running on psp, >> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP. If the UMD has a high version than ur console, u need to update ur psp.
plz visit my blog, for psp update guide.
Oct 28, 2007 | Sony PlayStation Portable (PSP) Console
Same with my PSP. My son accidentally broken a spring sensor for the UMD when you close the UMD cover of the PSP. That's why the drive doesn't recognize if there's a UMD. Sony Service Center here in the Philippines doesn't have a replacement part for this.
Aug 19, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
