Question about AEG Washing Machines
I have error codes E50 and E5E. What is the problem please
3 Suggested Answers
SOURCE: E50 code
Had to phone zanussi. Catch 22!!
Posted on Jul 22, 2008
  • 1531 Answers
SOURCE: error # E5E
this is a communication error between the main contorl board and the speed control board check all the wiring harness and make sure they are in good order.replace the main control board if the problem continues replcae the speed control board
Posted on Mar 15, 2010
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
Dec 21, 2014 | Electrolux Heating & Cooling
How do you fix an e5e communication error on a frigidaire washing machine?
Hey friend, thanks for your inquiry!
I see your Frigidaire washer is displaying an error code "e5e". However, it appears "e5e" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "e5e" you may want to seek assistance from a professional for proper repairs. -Matt
Oct 18, 2014 | Frigidaire Washing Machines
Electrolux front loader E50 error
Hello Friend, thank you for your post!
I see you are receiving an error code E50 on your Electrolux dishwasher. Is it possible that the code is missing characters? Could it possibly be an E50? May I please have your model number? The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can further address the issue at hand. In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display E50. Thank you - Z.
Apr 12, 2014 | Zanussi ZWF1640 Front Load Washer
Gltf2940fs
washer stopped working, displayed E5E error when prompted for code. I opened up the back of the machine and noticed that a connector was not connected to the control board, i removed the control board to get a better view of where it belonged, and slid the connector over the control board, closed up the machine and it's back in business.
Apr 28, 2013 | Frigidaire GLTF2940F Front Load Washer
Error code E5E
E5E is for the control board failure. Here is the replacement part.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire model is GLTF2940FE0 front loader will not start
I was wondering did u ever figure this out i have same code ...but mine will run a little water then drain and never spins but got the code E5E too
Dec 15, 2012 | Frigidaire Washing Machines
I got an error code e5e from frigidaire front loader
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Dec 15, 2012 | Frigidaire ATF6000ES Front Load Washer
E50 code
hiya
i'm sure that e50/e51 is the insulation in the motor breaking down, in which case its usually new motor time i'm afraid.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 20, 2008 | Zanussi ZWF1640 Front Load Washer
Washing Machines Logo
230 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
