Question about Rowenta Irons
The white wire from power cord connects to what position in the connection block? it looks like it goes into bottom right hole along with the red wire that goes to bottom heating plate , but the black wire from power cord looks like it goes into top right hole which does not seem correct.
  • 4 more comments
  • luckyjrm Sep 01, 2010
    model dg5030
  • luckyjrm Sep 02, 2010
    i have not hear from you so i am not sure if you received my reply to your question concerning model.
    model DG5030
  • luckyjrm Sep 04, 2010
    the way it is now is; first space on right in connector block has yellow on top and yellow on bottom. second slot on top small red wire going to trigger on handle, green from power cord and on bottom two blue wires, and third slot on top is black from power cord but have two white wires left. one goes to heating base the other white is from power cord. it looks like thy go to the lower slot in connector but can the white wire in power cord connect to black wire from power cord?
    the way it is now is; first slot in connection block top is yellow goes to light, bottom yellow goes inside iron to thermostate
    second slot top small red goes to trigger also in that slot is green from power cord. bottom second slot two blues ,one goes to trigger the other goes inside iron to thermostate third slot top is black wire from power cord. which leave me with white wire in power cord and red wire to heating base. do these two wires go into bottom third slot? that does not seem correct since black and white would be connected together, but there is no other place to put them.
    the power cord does not have a ground prong.
  • luckyjrm Sep 06, 2010
    i have a towenta steamer. model DG5030. i need the wiring diagrahm or instructions on where the wires are connectd inside the iron part of the sreamer. the cord from the steam reservoir
    has the steam hose and a power cord with green,black, and white wire. i need to know how they are connected in the back of the iron.
    President:
  • 2,047 Answers
Electrical color coding differs from country to country. But most universal is the red and black wires. The red and black wires go to the bottom holes. Red stands for live while black is used for Neutral any other wire which might be encountered usually represents the earth cable in your case the white one and this usually goes to the top. The connection block differs also from country to country so i am sorry i can not say specifically where the red and black goes but they can always be used interchangeably as they cause no harm. Hope this solution has been helpful?
Posted on Sep 08, 2010
    Guru:
  • 642 Answers
Power cord wiring standard:
  • Green : Earth
  • White : Neutral
  • Black : Live/phase
These 3 wires should not be connected together at all.
Posted on Sep 06, 2010
  • Rene Rossouw
    Rene Rossouw Sep 06, 2010
    Please do not attempt to plug this unit into the wall socket if your homes' wiring is not fitted with earth leakage detection. Unplug other electrical appliances(radio, tv, computer, fridge) from their wall sockets before plugging in this unit. This will prevent damage from surges caused by the possible tripping of the earth leakage.
    Judging by your comments there are only 3 connector positions therefore one for each of the wires in the power cord. The Black being the Live should go directly to the on/off switch and have no other wires connected to it. This is standard practice with appliance wiring. The White inside the unit which you have left over is most probably the power switch and should therefore connect to the black.
    Each of the heaters (sole plate and boiler) will have 3 connections.1 Live supplying power, 1 neutral for the return path and one earth for sensing power leaks. Connecting the earth to the wrong lead from the power cord will trip the earth leakage on yopur distribution board.
    If you have an ohm meter/multimeter handy you can check which wires are earth. Place one of the meter cords on the sole plate and the other on the wire you want to test ie blue(which are currently connected in the middle presently and to power cord earth) Remove the blue wires from the conector. Measuring between the blue and the iron soleplate, should give a 0 ohm reading which indicates the 2(sole plate and blue wire) are connected and confirms that the blue wire is indeed an earth. The other blue should then be the boiler earth and can be tested between a metal part of the boiler or base and the wire.
    This is what I've been able to deduce from your posts. Internally you have :
    • Red leading to boiler
    • 2 yellow leading to ???
    • Small red leading to trigger switch on the iron.
    • 2 blue leading to ???
    • 1 white leading to ???
    If you can give me an indication of all the wires and where they lead
    to I will be able to tell you how to wire it without injury to yourself or damage to the unit.
  • Rene Rossouw
    Rene Rossouw Sep 08, 2010
    Terribly sorry for only getting back to you now. I have just read through your comments and am still a little in the dark so perhaps we can decide on some component names just to be sure.
    Base : the portion that water gets poured into. The base contains a power switch. It also has a steam output control dial that controls a thermostat which in turn controls the boiler/steam generator in the base. It also houses the connector block that holds the wiring. And the power cord from the wall outlet also enters into this part.
    Power cord : The power cord from the wall oulet is supposed to only contain 2 wires(2 pronged plug). Yet you mention 3. Black Green and White. If at all possible could you get your hands on an ohm meter/multi meter and
    determine which of the 2 prongs on the plug connect to which of the 3
    wires in the outlet power cord. Do this by setting the meter to
    resistance and touching one lead to one of the prongs on the plug and
    the other lead to any of the 3 wires. If you get a reading then the 2
    that you are measuring are connected.
    Connector block : Is seperated into 3 portions. Each portion has wires entering from the top and bottom. Wires in one portion entering from the top also make contact with those entering from the bottom, or are they seperated? I believe not but would like to confirm with you.
    Steam hose : Leads from the base to the iron. This in fact contains not only the steam hose but some wiring. Which colors?
    Iron : The handheld portion that does the actual work
    You mention a light. Is this the light in the iron? Or the steam indicator light?
    You also mentioned the trigger? Do you mean the iron or the actual steam trigger in the iron?
    Bear in mind this unit has 2 thermostats, and 2 heating elements. One of each in the base and the iron.
    Unfortunately, unless you are an approved repair centre, there is no repair manual or diagram available anywhere, and Rowenta are of no help at all.
  • 4,924 Answers
It is correct that the black wire to be apart cause it is the ground one ...so ..if the red is already connected that is the positive ..connect the white near it in the other one ...as negative ..and the ground leave t connected to the case..
Posted on Sep 02, 2010
    President:
  • 1,961 Answers
Please indicate the exact model of your iron so I can give your the exact wiring diagram. Thanks. please post back.
Posted on Sep 01, 2010
How do you open the back plate to access the power connection. On a shark model G1568 iron??
We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
Jun 08, 2014 | Euro-Pro Irons
How can I get my steamer to work again? Orange light comes on but nothing else
Make sure you didn't knock off a wire to the heating element when you had it open. Also put a couple of cups of whitevinnegar in it and leave it for an hour or two. This will dissolve the scale build up. If it doesn't get hot thenthe element is probably burned out. There is a limit switch held against the tank too. It can stop the heating element if it goes bad.
May 29, 2014 | Rowenta IS9100 1550W Precision Valet...
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
I have an older (1997) Rowenta DE 11 Powerglide iron. In the process of cleaning it, I mixed up the order of the wires. The colors are brown with the power cord, dark blue with the power cord, blue by...
If you can take a sharp picture of the circuit board and send it jodamechanical@aol.com I might be able to help you.
P.S. Make sure all wires and circuit board are clear.
Feb 10, 2011 | Rowenta Powerglide DE011 Iron with Auto...
Hey there, Please guide me for the wire connections for Shark GI490 Iron along with the color code so that it can work back again. I will appreciate you assistance.
The advice given here is totally incorrect. Please ignore Azraelsrl solution. Being incorrect makes it very dangerous!!!
Blue or black = Neutral red or brown = phase green or green/yellow = earth.
If in doubt, you should get a qualified electrician to replace the cord to your iron. Getting it wrong... can easily kill someone!!!
regards robotek
Dec 06, 2009 | Euro-Pro Shark GI490 Iron
Panasonic iron NI-A56NR wont turn on
first test your heating element to see if it is working.
You can by pass the control module by removing it from the line. Just disconnect all wires that goes to the module and put aside, then, connect back lead to the far right connection and white wire to the third connection from the left. Be careful playing with electricity is hazardous to yout health if you don't know what you are doing.
Jan 17, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
Dec 13, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Attaching a plug in cord to a philips Electric Steam Iron
i need a new wire--mine had a short in it--how do I go about repairing it?
Jul 04, 2008 | Irons
Irons Logo
104 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
