f you are experiencing issues when using a Universal Media Disc (UMDā¢) on the PSP system, try these troubleshooting options:
Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Hi Jleew,
You should check to see if another UMD will work first. Also try them in another PSP. If your sure your PSP is not reading Discs, then and only then, Clean the Laser lens carefully. Using a strong flashlight and magnifying glass, look into the UMD drive with the UMD door open and look for debris like hair or lint, and also dirt and dust. A black switch pokes up on the left inside the UMD drive. Its a little black stick. When you press down on this Black stick, your UMD disc motor should spin for second or two. The UMD laser lens should light up when your press this switch. If any of this does not happen, you need to replace the UMD drive. If you need someone to do this which if you have never done it, you need some knowledge big time.
I can do this for you if you're in the USA for $55 including a New UMD drive, REturn Shipping, and 90 day warranty. Contact [email protected]
when i try to play a movie it says region code incorrect...what the hell does that mean?
I can not get the umd logo to appear, nor does it show up when there is no disk.
