Question about Refrigerators
Water and ice i cant secive from my despener from the door
  • 117 Answers
Make sure that your water under the sink for the ice maker is open
Posted on May 10, 2008
No water from despener
Most times the problem is caused by the dual water control valve that controls the water dispenser. Other things could be frozen water inside the water filter assembly, lines or dispenser. Also problems with the dispenser controls=> WR55X10446 Location number 93 => HSS25GFPAWW Freezer Door and Dispenser
WR57X10051 Water Control Valve
Here is a=> Service Manual Please remember that the service manual covers all models related to yours and some parts in manual will not be related to yours.If you would like to test the water control valve carefully apply 110 VAC to the water dispenser side or check the coil with an OHM meter. I will be here to answer your questions if you need more answers but at this moment I feel the problem is the dual water control valve , Thanks, Sea Breeze
Jun 28, 2011 | Hotpoint HSS25GFP Side by Side...
My side by side refri w/ice and water in door makes ice but cant ice from tray to door
Mine just started doing the same. I purchased this one on Nov 08, 2008. If I take all the ice out of the tray I can see the auger turn and if I put back just a few cubes the system delivers ice thru the door. But, put too many cubes in and the auger won't turn. Piece of junk - out of warranty and and now I pay more to get the buggar fixed. I need to try another company next time.
Aug 30, 2010 | Whirlpool ED2FHEXN Side by Side...
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker stopped working, we have checked the water hose and their is water coming from the dispenser at the front of the door.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 29, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool ice maker makes impure ice but the water is crystal clear and good. replaced filter and cleaned ice maker tray ect.... no change. Is there a way to sanitize the water line to the ice maker?
what you are seeing in the ice is the impurities in you water. you wont see them until the water freezes because you are trying to freeze the "H2O" and not the calcium and magnesium. those are what causes your ice to look cloudy.
filtering the water does help but you cant get perfectly clear ice with this type of an ice maker.
when you see "store bought" ice and it is clear, that is because it is made a different way to prevent the impurities from forming in the ice.
also the longer the ice is in your freezer, the more it will absorb from the air causing even more cloudiness.
Jan 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
Water despenser in door drips water
Hi!!! you seem to have a problem that everybody in the world has..Its normal at there is nothing you can do about it unless you install an antisyphon in the water line kitchen aid has one.Good luck..
Jan 05, 2009 | Frigidaire FRS23H5AS Side by Side...
My side by side whrilpool refreg
First of all, is there a reset button that needs to be pushed after changing filter? Mine has one. Check around the sides and top inside the fridge for a little button and push it in.
Is the water turned on going to the fridge?
If it was working before you changed filter, maybe the water line got kinked somewhere and no water can come through.
Also, if filter isn't reinstalled correctly, no water can come through it. Make sure the filter is not upside down and that the holder is screwed in all the way.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
