Question about Emerson LC320EM9 32 in. LCD HDTV
I HAVE A PL-P42W-10A EMERSON 42" PLASMA TV THE CHANNEL STRTED TO TURN BY THEM SELFS THE THE TV TURNED OFF THE UNIT STILL POWERS BUT NO PICTURE COMES ON AND NO SOUND
5 Suggested Answers
SOURCE: I am having a hard time finding a manual for an
Had the same problem but found my manual. I scanned it in. You can upload it here:
http://rapidshare.com/files/420010686/Emerson_Plasma_TV_PL_P42W_10A_User_Manual0001.pdf
Posted on Sep 19, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Emerson plasma
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Feb 16, 2011
  • 718 Answers
SOURCE: I need a mounting stand
Search on Ebay.com for;
emerson pl-p42w-10a stand
Posted on Feb 26, 2011
bendarden
  • 984 Answers
SOURCE: Software Upgrade for Emerson pl p42w 10a HDTV
Make the FixYa experience better for everyone by voting.
I think you mean a firmware upgrade. In any event, you can access the Emerson download site by clicking on the following link. CLICK HERE
All the best,
Ben
Posted on Nov 20, 2011
Directv can't connect my tv to he, what can I do, they say I need a green plug in in the back,with the red, yellow, white
What I believe they are trying to tell you is you need to hook up into a component input . It is a video input only and it has three jacks usually coloured red green and blue. Match up the colours with the receiver and you will get an HD picture. They way you currently have it hooked up is a composite connection with only the yellow being for picture. This cannot get you an HD picture. The red and white is for the sound. I don't know what you mean by he though.
Sep 24, 2015 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
Video settings don't hold for more than 15min
Check capacitors. There are some very inexpensive meters for this and cheap capacitors are behind many problems in electronics. Once you find it is a bad cap you can replace it or the board.
Sep 05, 2014 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
Need to know how to set my flat screen back to its original settings. Emerson 42" flat screen Model: PL-P42W-10A
Well I am unable to find the manual for this particular model but there should be something under settings to reset your flat screen. I was reading another forum and I believe it would be on page 4.
hope this helps
Sep 02, 2013 | Emerson Televison & Video
All the best,
Ben
Nov 19, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I need a mounting stand for a emerson model #pl-p42w-10a
Feb 26, 2011 | Televison & Video
I have an Emerson Plasma TV (PL-P42W-10A) and it cuts off the top and bottom of the screen. It just started doing this. The only sizes that are available are 16:0 Zoom1, Zoom2, and 4:3. The Wide Fit and...
Our prolem is no matter how we adjust the screen when ever there message at the bottom of the screen this don't show up or is cut off. I get upset when I pay the amount for this 42" Plasma TV and watching the news there extra messages across the bottom of the screen espically when school closing due to weather. I've try to figure out using the instruction booklet with no results. Any ideas where the screen to where extra messages in lower screen can be seen to be read?
kimandtomaleexander@gmail.com
Oct 26, 2010 | Emerson EWL3706 37 in. LCD Television
Emerson LC320EM9 32 in. LCD HDTV Logo
365 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
