Question about Oster 5838 ExpressBake Bread Maker
How long is the baking time? - Oster 5838 ExpressBake Bread Maker
  • 268 Answers
You can download a manual at the bottom of this age. That should tell you baking time depending on what you are cooking. Also there are sites with reciepes and they also indicate how much cooking time is needed.http://www.devicemanuals.com/guide/Waffle%20Maker/Oster/Oster-5838-Expressbake-Breadmaker-User-Manual-==TWpZMU56VTI=.html
Happy cooking!
Posted on Sep 01, 2010
My new Breadmaker machine won't bake the bread.....does everything else but won't bake.
If it is new then it should be under warranty. Take it back to the store for an exchange as it appears to be faulty.
Jan 25, 2015 | Breadman Kitchen Appliances - Others
Can I add baking time to aBreadman TR442SPR? I did not receive a manual with my machine and the bread is not completely baked.
If you have a program that says "Bake", select that then push the "up" on your control panel. Each time you push the arrow you should add 10 minutes to the "Bake" stage. push it twice you get 20 minutes of additional baking etc, etc, if you like this answer please vote and leave me some good feedback....thanks rmpgda!
Sep 16, 2011 | Breadman TR442 Bread Maker
Can you tell the difference between the bake function, fan bake and classic bake.
Sorry to read about your problem, I hope this helps you out.
fan bake gives you faster and more even baking and browning ..thats all
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Frigidaire FEF312 Electric Kitchen Range
My bread machine was unplugged with about 20 left in the bake cycle. How do I get it to go bake into the bake cycle. Display panel is unlit
If your machine has a "Bake" cycle then choos that cycle and push start and adjust the timer so it cooks the right length of time. Your manual should tell you how long the the last bake cycle takes and just push your timer until that time is set less the 20 minutes already baked.
Nov 05, 2010 | Oster 5834 ExpressBake Bread Maker
Time bake
No, time bake is what time you want the unit to start cooking and what time you would like it to stop cooking. Or turning the oven on and turning itr off. the timer on the unit will just count down.
Jan 12, 2010 | Ovens
Electric oven will not maintain temperature. drops 20 degrees
Jump online & get the schematics for your oven.. You'll need to troubleshoot the bake circuit, which is comprised of 2 - 120VAC legs (240VAC is applied during bake). One 120VAC leg is from the DLB relay and the other is from the Bake relay. if either one is bad, or not energizing, you won't get any power to the bake element. (The bake element runs 100% of the time during the bake cycle. broiler only operates 25% of the time during bake) I have had luck re-soldering the relay leg nodes on the backside of the relay board, as they develop "opens" over time. The relays are designed for ridiculous ##s of cycles, so they're not *usually* bad.
Dec 23, 2009 | Amana AOCS3040 Electric Single Oven
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Delay or time bake
You can find the manual at www.managemyhome.com, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Jan 30, 2009 | Kenmore 47772/47774/47779 Electric Double...
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Oster 5838 ExpressBake Bread Maker Logo
93 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
