Question about KitchenAid KERC500 Electric Kitchen Range
I have a Kitchenaid model YKERS507EW1 and the probe light comes on as well as sometimes F4 and then oven shuts down. I have already replaced temperature sensor and that is not fixing the problem. I now want to disconnect the meat probe and wondered if I can just unhook from back of stove and leave unhooked. Is this safe to operate this way or should I be doing something else. Thanks so much.
  • btfam Sep 02, 2010
    This was very helpful. I actually just tightened up the meat probe outlet and it is working so far. If this does not work I will get an ohm meter, test it out, then replace, only if necessary. Thanks much.
    Thanks for your quick reply. My first time using fixya and will use again. Very helpful.
  • 2,272 Answers
Its not safe to use the unit with unplugged meat.It will not work properly and also other parts can get short. But for troubleshooting,i will say try this procedure:--- F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78k? at 60° F [15.6° C],
37k? at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 01, 2010
Kemc377. Why is it showing error code?
F1 DOOR SWITCH
F2 KEYPAD
F3 TEMPERATURE SENSOR
F4 MEAT PROBE SHORTED
F8 SELF CLEAN LATCH PROBLEM
All other errors, replace the main oven control
Aug 23, 2015 | KitchenAid Ovens
Hi, my kitchenaid oven model ykers507ew1 is doing the f-4 meat probe game. cuts out after a moment and will not bake. I have the top removed to expose all the wiring and the rear cover off, looking for...
The problem you describe is with the temperature probe which is short circuit and which need to be replaced.
We have here below the link with the parts diagram of your model where you find the temperature probe and also you can order the part from the same link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136688&diagram_id=28294584#d28294584
Jul 11, 2011 | KitchenAid KERC500 Electric Kitchen Range
Whirlpool Oven has error code f4-e411
F4 Shorted oven temperature sensor Replace oven temperature sensor
Jun 11, 2011 | Ovens
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
What does F4 mean, oven shuts off and code comes up?
The code indicates an Open or shorted oven temperature sensor. Solution is replace oven temperature sensor Here's a link to a short tutorial on how to make the repair... http://www.applianceaid.com/changingoventempsensor.html
Oct 18, 2009 | Whirlpool Ovens
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F4 fault code
sounds like the meat probe is defective. have it replaced again.
Sep 13, 2008 | KitchenAid KGST307 Gas Kitchen Range
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
Feb 12, 2008 | Frigidaire GLEB27S7A Electric Single Oven
KitchenAid KERC500 Electric Kitchen Range Logo
232 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
