Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Red Light Blinks 3 times
Help.. I have replaced bulb that went out then fan motor goes out. TV repair man comes gets fixes it works great for 3 days NOW tv went off and red light blink 3 times then stays solid then blinks 3 times (repeats) can anyone give me any ideal?  Thanks
  • CrazyCard May 10, 2008
    Thank you very much yankeegurl for this info.
  • 121 Answers
That models plagued with bad capacitors 1000uf and above the problem you describe is 2 bad capacitors on the PWV board if you would like more information you can go to this link they have service manuals,parts and experts online for these tv's leave them an e-mail with your model number and problem and they will help you I have used this sight many many times myself
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
Replaced bulb in kdf-50e2000- when powered on green light flash 3 times & fan engages, 2 seconds later fan quits and i get a 3 red light blinks
impossible to actually see if lever is Fully engaged---with door off try to engage with a match stick or something not metal--see if set comes on that way.
Apr 20, 2012 | Televison & Video
Just replaced the lamp, worked for about 3-4 days, tv won't turn on, green light flash about 3-4 times then a red light flashes, waited about two days, tv came on and worked for about 1 month now the same...
I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
Jan 20, 2011 | Sony KDF-50E2000 50" HDTV
Sony tv model kdf 50e2000 shuts off and red light blinks 3 times.
You need to open up set and clean out all fans of dust or the new bulb isnt being cooled, or the color lcd isnt being cooled shutting TV off.
Apr 17, 2010 | Sony KDF-E502000 50" HDTV
I try to turn my Sony Wega 42" Rear projection lcd tv on , but the power light goes once to green then blinks 3 times in a row, for a number of times before it just goes to red, when it shuts off...
I am posting here because I read the response the other person gave you.
Are you saying the set does not turn on and the red light blinks a sequence of three red blinks several times?
Confirm actual model number---3 red blinks is an error code---Get me Model number (KF50WE610?) and I will try to give you a simple answer---If it is what I think it is---3 blinks may have a easy repair that anyone can do.
Dec 31, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Kds60a2000 tv won't switch on red light blinks 6 times if i turn tv on the green light blinks then it goes back to red light this is the power light
Have you tried putting in a new bulb for the screen. Our TV did that and it was the bulb needed replacing. Ours is on the side towards the back. You can order it online, its cheaper than paying a repair man to do it. The first time we did it cost us 500 dollars and then the second time it happened I ordered off ebay for only 170 dollars. Big difference Huh ;) Good Luck
Nov 12, 2009 | Sony KDS-60A2000 60" HDTV
I have the 50" SXRD XBR1 grand Wega; This has been a great set for 3+ yrs. A flashing red light promted me to replace my original buld (this site). I now still have a flashing red "power" light, shuts off...
Its the fan that cools the bulb. Try turning on the tv and look at the fan to the rear of the bulb. If the fan is not spinning that is your prblem. The tv has a safety switch that will cut off the tv if the bulb gets too hot. I was able to tap my fan with a pencil and get it spinning, but that is just a temperary fix. After a while, you will find the fan will stop working all together and it will need to be replaced.
Oct 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Panasonic 42 inch television
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
