Question about Weather King Heating & Cooling
The fan on the unit outside is not turning. i've tried to trip the breaker box and that's not working. The fan is blowing in the house.
  • 107 Answers
It sounds like maybe the fan is not coming on outside but the compressor is running and just tripping on internal heat protection .... Please turn power off to the outside unit and let cool for 15 minutes then remove electrical compartment cover and see if the contactor is pulled in.. if its pulled in then look at the capacitor that is usually sulver and round with wire terminals on top.. it should be flat on top and not rounded.. if its rounded then replace it by ordering part online or contacting locar electrical parts company or if none of this looks to be the problem please contact a local a/c repair company.
Posted on Sep 01, 2010
Not cooling
are you talking about a central a/c system? the fan that blows is the indoor air fan? check breakers for outside unit. one breaker in the house panel box and a breaker at the outside unit. because other wise tha cap or contactor (for the outside unit) may be bad. both of witch may keep unit from turning on. unless you are knowledgeable about electricity I would not recommend opening the outdoor unit. you could get electrocuted. safety first
Oct 11, 2015 | Heating & Cooling
I have a question about a Carrier Air conditioner. It's an outside unit and it's old. When I turn the air on the air blows from the inside heater/air unit upstairs in the wall. Outside the air con ...
Could be just a blown fuse or circuit breaker. Fuses are generally located close to the unit in a small box on the side of the house. You will have to flip the box open to find the fuses. It may have a cartridge you have to pull out. Fuses are not visibly bad, you have to check them with an ohm meter or sometimes a hardware store can check them for you. Otherwise you will have to buy two and just replace them both.
The circuit breakers are usually in the house along with all the other breakers in a main panel. There will be two breakers and will probably be visibly tripped. Just flip them all the way back and forward to reset
Aug 03, 2011 | Goodman CKL49AR49 Air Conditioner
Breaker trips on unit. Fuse in house is ok. As soon as AC unit turns on it trips the breaker outside next to unit.
you have a 'direct short' - most likely the compressor or fan motor.
you could isolate it to one or the other by (be sure all power is off) disconnecting one of them and turning the unit back on.
For example if the fan motor is shorted and you disconnect it - the breaker will hold and not trip and the compressor will come on - which will tell you that you need to replace the fan motor.
If you do this and it still trips the breaker then reconnect the fan motor and disconnect the compressor and try that.
If the breaker holds and the fan motor runs then you know the compressor is shorted.
Note: the fan motor can be replaced with not a lot of trouble depending on how mechanically inclined you are - but the compressor will take a qualified serviceperson.
Jun 06, 2011 | Heating & Cooling
First time using my air conditioner after winter. my "inside" fan will run but the outside unit is not starting. My weather king is approx 9 years old
Check fuses and circuit breakers to the outdoor unit. Fuses should be right next to the unit in a box on the side of the house. Easiest thing to do is replace them both. Circuit breakers are in you circuit breaker box. There will be two of them, probably 30 or 40 amp maybe 50 amp if a big house. Trip breakers all the way back and then all the way forward. Hope this works.
May 11, 2011 | Heating & Cooling
The a/c unit outside doesnt come on but the fan inside of the house is blowing, the unit is not cooling the house. I have a goodman unit.
Hi, this is a split system Goodman. With the j36 in the model number, that tells me it is a 3 1/2 ton unit. If the outdoor condensing unit is off and doing nothing at all, no fan on top running, no compressor or anything, it sounds as though you have lost power to it. The high voltage to the outdoor unit is seperate from the indoor unit. When it is not running, you have only warm air from the indoor unit. Before I have you do anything, go out to the unit. Take a water hose being careful not to bend the fins on the coil, and wash just the coil very good. If its dirty, it can cause the pressures in the system to rise very high and blow a fuse or trip a breaker. When you are done washing it, you should have a electrical box mounted on the wall that feeds power to this unit. First, find your main breaker box to your home. It should be where the meter is. Find it and it will have several different breakers in it. They may or may not be marked. Look for a double - pole 30 to 40 amp breaker that should say a/c, if it was marked. If not, look and touch them, it will be 2 breakers together and feel if they are tripped. If so, turn it off with a hard motion. Then, back on the same way. Watch to see if it holds and does not trip on you. If its ok, go to the outdoor unit. Make sure the thermostat is on auto/cool and turned way down for it to come on. If it was a breaker and its running, more then likely the dirt from coil caused it to over amp and trip. Now, if there is power and breaker is on but still not on, open the box at the unit. It may have a pull out type plug, or breakers. If it has a breaker, turn it off and on like the other. If it doesn't, behind a plastic panel you will have 2- fuses. Turn off power at main box breaker, and remove both fuses. They are cheap, so go get 2 at a hardware store and replace them. You can have them ohmed out to see if one was bad. After installing the new ones and you turn it on, and all is good, that was your problem. May sure you have power to this outside unit. If it was a blown fuse or tripped breaker and this continues to happen, you may have a internal compressor or condenser fan motor problem. Try the things I have said first. This may be the only problem you have. I do this for a living, 33 years and a licensed contractor. Please keep me posted and I will continue to help you if you need me. Let me know after you check everything.
Sincerely,
Shastalaker7 :)
Apr 11, 2010 | Goodman CLJ36AR42 Air Conditioner
Inside the air is blowing, but the outside unit fan isn't moving at all. HOUSE IT HOT!!!
Two things; outside does the compressor try to come on? If not you may have a switch\Thermotat problem. Also make sure the breaker to the outside unit hasn't tripped. If it has tripped there may still be a problem after you turn the breaker back on. If it's only the fan that's not coming on outside you will need a new capacitor or fan motor and compressor(if the fan motor is replaced you should have a new capacitor also. If it has been intensely hot your unit might have just gotten overworked. Then resetting the breaker is all that is needed. If you have continuos resettings you MUST call a qualified HVAC Tech.
Jul 12, 2009 | Goodman CLQ36AR49 Air Conditioner
Heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Fan
Ifs its a small humming sound,then its the contactor pulling in. But if it a loud humming sound then its the compressor kicking in. and the fans not, try to take something long and turn the blades on the fan, if it takes off and run then your capacitor is shot or swollen at the top,which was cause by power surge. Take-off and replace with the same mfd. writings ,on the outside of can. Also check for blown fuses or tripped breaker . the fuses should be in the disconnect box on the wall, or the breaker in the breaker box.. Older house has fuses instead of a breaker box!
Sep 01, 2008 | Bryant Heating & Cooling
A/c unit not working. Have thermistat set on 65 and temp. in house is around 85. check the breaker box for the house and it have not tripped
You must make sure that there is power to both the inside unit and outside unit. Is the room air blower blowing? If not you have either a plugged filter, iced up coil, the access door is not quite closed or there is no power to the unit. Is the outside unit fan turning? If not, you either have no call from the thermostat, the fan is broken or the unit has no power to it. I would turn off the breaker to the inside unit and switch the breaker near the outside unit to off and let them sit idle for 5 minutes. Switch both breakers back on and chect to see if the outside unit turns on. Then check the indoor unit and see if this starts blowing. Let us know what you find.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
