Question about Fellowes Office Equipment & Supplies
Where can I get a Manual for the PowerShred 410? We need to repair it. Stopped shredding; now no action of any kind when plugged in.
SOURCE: Fellows Powershred c-120 c indicator lights
your bin full sensors are dirty or broken to clean access bottom side of shredder head and look for a set of screws on each end of the paper throat. There you will see two little bulbs (bin full sensors) these have more than likely gathered paper dust and need to be cleaned with a Q-tip dipped in a little Isopryl Alchohol. This should solve your problem. If you have any questions just call us at 1-800-945-4545. A Customer Service Representative will assist you.
Posted on Apr 23, 2008
t_vinson57
  • 58 Answers
SOURCE: Powershred PS 70
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 32 Answers
SOURCE: Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
Posted on Sep 01, 2009
haystack11
  • 55 Answers
SOURCE: we have a Fellowes Powershred C-220C and the
Only if you are mechanically handy and know how to take a part. Most of these shredder's sensors are PLASTIC and break EASILY. I should know, I had to take apart my wife's shredder.
I had to bypass the sensor and rewire it. It can be done if you know what you are doing. If not, don't try it
In your case I would unscrew the top assembly. Than I would use a can of canned air to clean out the sensor eye. Than I would use tweezers to pull out all specks of paper I could find.
Your best bet is to try to return it for a replacement.
Posted on Sep 24, 2009
Testimonial: "Thanks! I will see if our janitor can fix it Bev"
  • 41 Answers
SOURCE: not completely shredding. one side only makes
need bearing plate call cooks mobileshredding inc. or email cooksmobileshred@bellsouth.net or call bill cook or beverly miller 901-565-8188
Posted on May 10, 2010
We have a Fellowes Powershred C0320C shredder which will does not take the material to be shredded except on one end and does not pull it in and shred it.
Try to use the reverse action of the shredder. This runs the shredder blades in reverse and sometime CLEARS the left over shredded material that can cause a malfunction. Careful...watch your fingers as the blades are sharp and they can injure you. Never place your hands or garments near the open blades when it is plugged in.
Check also that the small switch is free and clear of derbies. When the cutting gears are in place on the container box, the small actuator switch is free to turn on or off until the shredding box is full. Once the box is full of shredded material the switch will turn off (a safety provision) and you must empty the container before it will operated again.
Jan 12, 2018 | Fellowes Office Equipment & Supplies
THE SHREDDER ISNT SHREDDING ANYTHING ANYMORE, the power still runs and it will still take the paper but its not shredding anymore???
You wil need to Have the shredding head rebuilt or replaced. and or a new machine. A new head is very expensive. Here is the number for fellows 800-955-0959. Check on parts if they are still available. Hope this helps your friendly service tech (colorado).
May 06, 2010 | Fellowes Powershred 220 Shredder
Not completely shredding. one side only makes
Apr 23, 2010 | Fellowes Powershred 220CC Shredder
Does not shred red light on
Try soaking the cutter blades with hot soapy water overnight thru the feed slot
Nov 04, 2009 | Fellowes Powershred SB-87Cs Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Won't shred
you have to replace the main power switch
Mar 31, 2009 | Fellowes Manufacturing FEL36055 Powershred...
PowerShred C-220 will not shred automatically
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
WITH MACHINE OFF
Hope this helps
Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Jun 16, 2008 | Fellowes Powershred 420 Shredder
469 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
