Question about Toshiba Satellite P505-S8945 Notebook
I want to replace my keyboard for my toshiba satellite P505
  • Toshiba Master
  • 5,660 Answers
Agree with LaptopRepair. The procedure for Keyboard removal is pretty close.
Wanted to add information on the FFC connector though.
If you have never dealt with a Flat Flex Cable connector, you are going to be in the dark, and could break something.
1) The flat cable from the Keyboard to the motherboard, is a Flat Flex Cable.
2) The connector on the motherboard the FFC connects to, is an FFC connector.
3) The Flat Flex Cable removes FROM the FFC connector.
> Just the flat flex cable, comes out of the connector on the motherboard.
Again, The flat cable by itself comes out of the connector, with no connector on it.
4) The FFC connector on the motherboard, does not come away from the motherboard. It is attached to the motherboard.
The FFC connector on the motherboard does not come apart in two pieces.
It opens to release the flat flex cable.
The FFC connector ONLY opens so far.
(1/8th inch ?) It is a two piece connector, but does Not come apart.
Looking at the FFC connector, you will spot a parting line going across the middle.
The top half of the connector looks like a fat T.
The two tabs on either side at the top of the Top half, make the T head shape.
These two tabs are pushed towards the LCD screen.
Ease one tab up a little, then ease the other tab up.
This opens the connector, and allows the flat flex cable to come out.
Install the flat flex cable from the New Keyboard, in the same direction as the old Keyboard's flat flex cable.
One side of the flat flex cable has exposed copper strips. (Contacts)
The other side does not.
Be sure to install the flat flex cable of the Keyboard in the correct orientation.
Do not rate this information. Just added info.
Posted on Dec 03, 2010
5 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: Replace keyboard on Toshiba Satellite 1410-s173
First remove the AC adapter (Charger) if plugged in. Then remove the battery.
Next step is removing the Keypad Securing Strip. This is a plastic cover right Above the keypad, and below the LCD screen. Looking at it, you'll notice on the Left and Right sides of it, that it has a U-shape.
This U-shape covers the LCD screen hinges.
Take a small flat tip jewelers screwdriver, and come from the right side of this plastic strip. You will see a thin parting line, where this plastic strip meets the laptop body. Your flat tip goes in this parting line. You have to use finesse. It's doubtful you'll break the plastic strip, as it's REAL tough! But if you slip, you could scratch the plastic. (Actually, it's pretty hard to scratch that plastic! Just thought I would caution you. The plastic strip is made of a spaceage plastic. Pretty tough stuff!)
The plastic strip has tabs around the edges, every so often. These
plastic tabs snap into place, and hold the Keypad Securing Strip on. When you begin, it's a little tough to get that flat tip down in there. (Remember ->Jewelers screwdriver!)
Plus, you may be at one of the points that there is a tab. Usually there is a 'dimpled' flat place, that looks like a flat tip should go there.
With the flat tip jewelers screwdriver inserted a little, ease back on the screwdriver, and lift the plastic strip up.
It will look like it's bending. If you have another flat tip Jewelers screwdriver, or a small butterknife, you can insert it, and hold this part up. Then take the other flat tip, move over a little, and start lifting up.
Once this Keypad Securing Strip starts coming up, it will come to one of those tabs, and the tab will come up and out. You'll hear a POP, and think you broke it! You didn't.
Go along the edge, and keep popping this strip up. Use caution, as to how far you insert that flat tip screwdriver!
There are tiny little wires under there, and you don't want to pinch one, or tear it loose. Keep the flat tip, about a half a fingernail length in, and you won't.
Once you get towards the other side enough, the strip will let loose, and come up.
Without disconnecting the wires, see if you can lay the strip towards the back, and lay it out of the way. Towards the LCD screen. You are trying to get to the screws, that secure the keypad. They will be in a metal strip for the keypad, and towards the LCD screen.
I can't remember at this point if there are two, three, or four screws. You'll be able to see, and you'll know.
(Use Caution! You can easily drop these screws! They might go right into the body of the laptop. You MAY be lucky enough, to pick the laptop up, turn it over, and gently shake the laptop, to have them fall on the table. You MAY not be so lucky, and have to disassemble the entire laptop, to get to them!)
IF, the Keypad Securing Strip will not lay out of the way, so that you can get to the keypad screws, you'll have to remove it.
It isn't tough, but it looks daunting the first time.
You will see small White connectors in the middle of the cables.
Two wire cables, if memory serves. These connectors are small White rectangular blocks. There is a Female and a Male. You just take your fingernails, and ease the connectors apart.
Don't worry about how they go back together. They are different sizes. You just match up the size.
Now with the keypad securing screws removed, ease the keypad forward a little, and bring the front of it up to a tilted position. (Towards the LCD screen is the front of the keypad) You don't want to bring it straight up, as there is a flat ribbon cable you need to disconnect. The flat ribbon cable attaches at the back of the keypad. (Towards you) It has a White connector.
This connector is different, from the ones you have disconnected already. The connector itself has a locking 'bar'.
This thin rectangular piece of plastic, goes across the length of the connector.
It is positioned at the front of the connector. It comes forward, towards the flat ribbon cable end, that is connected to the keypad.
It slides. It only slides so far, then stops. It is at this point, that you remove the flat ribbon cable itself. The one towards the keypad. There will be No connector on that flat ribbon cable. It will be just the ribbon cable itself.
When you reattach it, you just slide the flat ribbon cable back into the White connector. Then you ease that locking bar back into position. The position that it started from.
Now reverse your steps.
Posted on Apr 18, 2009
bahratt
  • 561 Answers
SOURCE: Replacing keyboard in a Toshiba P505 S8945 laptop
Removing the keyboard:
STEP 1 - Turn off the laptop, unplug the power adapter and remove the battery. In the battery compartment remove three screws securing the keyboard bezel.
STEP 2 - Remove the keyboard bezel with a small flathead screwdriver.
STEP 3 - Remove two screws from the keyboard.
STEP 4 - Lift up the keyboard as it shown on the picture and place it upside down on the palm rest.
STEP 5 - Unlock the connector on the motherboard and release the keyboard cable. Remove the keyboard.
Reverse these steps to install new Keyboard
www.irsivista.com for Toshiba Disassembly Guides.
Posted on Jan 14, 2010
puertobori
  • 7733 Answers
SOURCE: Do you know how to
fix-io-device-error-200x200.jpg Fix an I/O Device Error Columbus Administrative Services Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motorlike force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else.
  • Access "Control Panel" from the Start menu and then choose "Performance and Maintenance."
  • Click "System" and then go to the Hardware tab and click on "Device Manager."
  • Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; proceed to Step 4 to enable it. Otherwise, go to Step 5.
  • Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown, proceed to Step 5.
  • Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown, proceed to Step 6.
  • Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware.
  • Posted on Nov 09, 2010
    • 21 Answers
    SOURCE: i want to replace keyboard
    Try looking at this page. It may help.
    http://www.batterycentury.com/toshiba-satellite-p505-s8950-keyboard-p-79773.html
    Posted on Jan 15, 2011
    How to replace keyboard on Toshiba satellite c55t-b5230 laptop
    Toshiba Keyboard Replacement - Satellite Laptop - YouTube
    ? 5:19
    www.youtube.com/watch?v=F62RbnA06Fo
    Mar 6, 2012 - Uploaded by Jennies Garage How to remove and install a keyboard on a Toshiba Satellitelaptop computer. ... This video should help If I ever think ofreplacing the keyboard.
    Sep 17, 2015 | Computers & Internet
    Hangs Toshiba Satellite P505-S8940
    you can do either of the following to solve the problem
    • reinstall the computer with a Operating system that can ran under your laptop hardware requirements
    • cut and paste you files in the desktop to your drive D to offload drive c of your PC
    • increase your PC RAM size
    • uninstall software you dont nedd
    Jul 06, 2014 | Toshiba Satellite P505-S8940...
    Toshiba p505-s8945 bios stuck
    reset the bios jumper after opening the laptop...
    Jan 18, 2014 | Toshiba Satellite P505-S8945 Notebook
    Toshiba p505-s8945 hangs after pressing f2 or f12. Wont go to bios or boot???
    remove your hard drive it will be ok...your hard drive boot sector is damage better to replace it..1st just remove it and see...
    Bios
    start your pc and press f2 or dell... the bios menu open..put the password and then go to security and disable the password and save setting,,,
    May 15, 2013 | Toshiba Satellite P505-S8945 Notebook
    I want to replace keyboard on toshiba satellite p505 s8950
    Jan 15, 2011 | Computers & Internet
    Replacing keyboard in a Toshiba P505 S8945 laptop and looking for step by step instrucstions.
    Jan 14, 2010 | Toshiba Satellite P505-S8945 Notebook
    How do I replace the keyboard?
    next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
    Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
    Keyboard inoperative
    press and hold fn and press f11.it sounds like you activated the sticky keys
    Nov 22, 2007 | Toshiba Satellite A135 Notebook
    Toshiba Satellite P505-S8945 Notebook Logo
    361 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
