Question about LG Dishwashers
I am receiving an error code of "LE" on my LG front-load dishwasher...What is it?
Just solved a LE error code on my dishwasher,,,,it was a broken wire caused from the black sound deadening material LG uses...apparently when the dishwasher heats up the black stuff becomes soft...wires become imbedded then when it cools and you open the door it breaks wires...easy solution...soldered wire, put a thin piece of plastic to where the wires couldnt get imbedded , put back together and works great
Posted on Jun 04, 2008
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
I get an LE error message on my LG Dishwasher. I replaced the pump. Still get the LE error. Replaced the main control. Still get the LE. No blockage in the pump. What now?
When you receive the LE error code, unplug the machine for approximately 15 - 20 minutes. This will reset the microprocessor.
Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor.
A breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire.
A couple of notes about this - there are at least three motors on this unit - the main pump, the drain pump, and the 'vario motor' which appears to control the direction of water flow through the sprayers. The main pump is the one likely to go bad. Another cause of the LE code is broken wires in the door. The wires in the door get stuck in the black sound insulation and eventually break. Sometimes, this causes the LE error code. Check the wires in the door first. They are located behind the large front panel. It's easily removed by undoing 6 screws.
Sep 06, 2010 | Dishwashers
LE error what is stand for?
LE ERROR CODE ON FRONT LOAD WASHER IS A FAULT CODE FOR YOUR HALL SENSOR
Jul 04, 2010 | LG LDF8812 Stainless Steel Built-in...
We have an LG front loading washer. We first
This could be a bad hall sensor or even a bad motor. The motor is warrantied for 7 years but, you need to call an LG authorized service center and provide proof of purchase.
Jan 24, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Repair code LE and bottom is flooded
I don't know if this thread will help, but you can have a look here: http://www.howtomendit.com/answers.php?id=28214
If not try the LG website which has support and fault codes to assist you.
Jun 18, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
Mar 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Jun 14, 2008 | LG WM-2277HW Front Load Washer
Dishwashers Logo
247 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
