Question about U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613)
I've reset the USR5461 and now it is wireless, but I want to set a password for it. We haven't used this router for a few years so we don't have a CD or anything... How do we go about setting a new password for it?
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP and enter WEP code it is your password to connect wifi. Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 01, 2010
I set up wifi network in my home and forgot the password I used to set it up. Is there any way to recover that password?
Unfortunately, no. The only way to access your network again is to reset the router by holding down the reset button on the back (you might need to unplug it, then plug it back in while holding the reset button). That will reset your web interface (navigate to 192.168.1.1 in your browser while connected to the router)'s username and password to some form of the following:
Username: admin
Password: admin
Username: admin
Password: password
Username: admin
Password:
NOTE: The last combination is a blank password.
Once you've entered your router's web utility, you can set up your wireless again. Don't forget to write down the password...I wrote mine on the router itself, because honestly nobody can see it because it's in my house, so I don't have to worry about it being stolen.
Jul 27, 2011 | Linksys Wireless-G WRT54GS Router...
I need IP address to change password
The default IP address for the US Robotics USR5461 Wireless MAXg Router is:
192.168.2.1
If the address has been changed then you will need to reset the router using a thin tool, such as a paper clip, to press in the reset button on the rear.
Jun 04, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
When trying to connect my iphone 3g to the wireless router i am getting the error message unable to join the network USR5461 even though I am using the correct password. what do i need to do to correct...
I wonder if your router is set to perform MAC address filtering. If so, you have to either find the MAC address of the iPhone's wireless card and add it to your router's appropriate list, or set your router to not filter by MAC addresses.
Just my 2 cents... Carlos
May 13, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
I have a U.S. Robotics USRobotics USR5461 Wireless router
heres the online installation manual http://www.usr.com/support/5461/5461-ug/index.html
see configuration tab - You will not be prompted to login the first time you connect to the Web User Interface during the initial setup. During the Setup Wizard procedure, you will be prompted to create a user name and password to log on to the router. If you create a user name and password, you will need to use these whenever you want to log on to the Wireless MAXg Router. The user name and password are case-sensitive.
------------- so if you cannot remember the username and password - you will need to reset to fsactory condition and reset all the settings in the router for it to work with your ISP again
the reset button is on the back - RESET Button: To restore the factory default settings, use a paperclip to press in and hold the RESET button for five to ten seconds. If the RESET button is pressed for less than five seconds, the Wireless MAXg Router will reboot.
Apr 24, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
Had to reset router to factory settings now want to reset pasword
If you have your router at default settings do the following.
Open a web browser and type 192.168.1.1 into the address bar. This should pull up the settings for the router.
The username is likely "admin" or "administrator" and the password "admin", "administrator" or "password". Once you're into the router you can change the settings as you wish.
Jan 27, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
Need security code numbers in order to install..usr5461 1.1
Are you looking for the wireless security key / password ?
That is set up on the router.
These are the settings of your router. To find out the code you will need to access the router set up interface.
Do you have any computer connected to the router or able to go online through the router ?
Use that computer to open the set up of your router.
Click Here for more info
Nov 13, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I forgot the router's username and password.
Try admin, admin. If that doesn't work press the reset button and it will restore the factory settings. You will have to reconfigure the router.
Jul 16, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Forgot passwrd on a us robotics router
Generally you have to push and hold the reset button, i suggest for 30 seconds, this should completely reset the unit, including passwords and settings.
Jan 29, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Laptop wifi cannot find usr model 5461
I use the windows wireless zero program which all I read is the best for wireless and aliminates conflicks
Dec 30, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
User name and password
Default Username - none (leave blank)
Default Password - admin (lowercase)
rate me solved if it helps thx
Nov 05, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613) Logo
176 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
