Question about Durabrand DWT1905 TV
Closed caption for durabrand
Suddenly the remote control of our durabrand television was not working, but it was set up in closed caption recorder then we bought universal remote... we dont know how to turn off the caption using universal remote please help me how
  • Anonymous May 23, 2008
    How do i turn off the closed caption with a universal remote?
If you have the menu button on the tv itsself then you can go from there to remove th closed caption
Posted on May 12, 2008
How do i get caption only on mute
On newer Sony TVs you press the CC button to cycle through the available settings for Closed Captions (CC): On, Off, and On when
Muting.
However, it looks like your factory remote control lacks a CC button and your TV menu appears to have a simple Off/On option for what Sony calls Caption Vision. If that is the case then you would need to manually turn on Caption Vision when you mute the television. That hardly seems like the solution you're after.
If you had an aftermarket remote control that could record macros you might be able to program it so that when you press the mute button the TV would mute and also turn on Closed Captioning. This would require the proper remote control and some expertise.
Aug 19, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do i add channels on my tv
The closed caption just suddenly appeared on my screen with no buttons pressed. It won't turn off. I no longer have the original remote for this Durabrand 13" DU1301 TV . I was using the Time Warner Cable remote and have a basic cable box attached to the TV. Everything was fine until suddenly with no buttons pushed the closed caption came on. Is there anything sort of buying a new tv to fix this
Sep 11, 2011 | Durabrand DU1301 TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Closed Caption Durabrand #1091A
Unless you can get at closed-caption settings from the front-panel menu buttons, you're out of luck. Many TVs have this problem. Without the original remote you don't have access to all functions.
Sorry there isn't a more hopeful answer.
Mar 08, 2010 | Durabrand DWT1905 TV
We have a durabrand tv and it is Du2701 model and we have a cable box hooked up to it and the remote that went with the box is running the tv. This remote got dropped and some button was pushed and we...
It sounds like there must be a captioning button on your cable remote (if that is the one that got dropped). You should probably call your cable company and talk to one of their service guys and see if they can tell you which button controls Closed Captioning (on my remote, it is clearly identified as "CC"). If that does not work, then maybe you can go to ebay and find a replacement remote for the TV. There should be a way to disable captioning at the set, though.
Sep 08, 2009 | Durabrand Televison & Video
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Recording with closed caption
Carl,
Better late than.. I think that the Polo can record the encoded closed captioning onto the HDD, but you have to have a CC equipped television to display the captioning.
The newer Magnavox and Philips recorders sold at Walmart record the captioning, and have the capability to display it even on sets without the built in CC decoder depending upon your recording settings. If you get a digital converter box and connect that as the source to your Polo, you can record CC displayed on the screen if you want.
tom
Nov 20, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Durabrand 13" DU1301- Closed Captioning
Use the "tv/cap/text" button on the original remote.
Nov 04, 2008 | Durabrand DU1301 TV
Closed captioning
use the one on yoursky remote it has its own subtitles.
Nov 07, 2007 | Durabrand DU1901 TV
Closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Aug 16, 2007 | Sanyo DS24424 24" TV
Durabrand DWT1905 TV Logo
325 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
