Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
My GE Profile Dishwasher Model # PDW7880J10SS does not start, the lights on the front panel are lite. Please let me know what I need to do.
4 Suggested Answers
  • 246 Answers
SOURCE: Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Posted on Feb 25, 2010
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Posted on Apr 08, 2010
  • 246 Answers
SOURCE: I have a GE Profile
yes, ApplianceArt.com makes custom panels. try them out, I think they are $70-$100. They also have a faux stainless that is cheaper and other sorts of designs and colors.
Posted on Dec 06, 2010
GE Profile mod. # PDW7880J10SS not cleaning, leaves film
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
My GE Profile dishwasher won't start. The power
More then likely the Control Panel has faulted and will need to be replaced. You can try shutting off power for a few minutes and see if it resets.If so great if not time to replace.Not that hard of a repair for a DIY
Jan 08, 2018 | GE 24 in. Profile PDW7800 Built-in...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher will not start
Check your receptacle where the d.w. is plugged into with a voltage tester if it works then un plug the d.w. and take the bottom front panel off.there is a small box where your power cord connects to..usually it has a 1/4 or 5/16 screw holding it closed.Open the box and check to see if the wire nuts are tight.This is usually where the connection is lost
May 16, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Rotating arms getting clogged very frequently
I do not have a huge amount of information about the GE Profile PWD7880 handy, so I don't know if it has a chopper blade/food disposer at the bottom of your Dishwasher, but when a dishwasher gets the holes of the spray arm, the most common cause is the chopper blade is jammed/blocked. Then the food debris never gets sliced and diced at the end of the of each wash cycle.
Opening up the filter under the spray arm, removing as much of the lower assembly and inspecting every where in the sump area, especially the drain pump area would be a great beginning.
Good Luck! Just ask if you have more questions.
Apr 04, 2009 | GE 24 in. Profile PDW7800 Built-in...
PDW7880J10SS: No water
First check to be sure that the valve that controls water coming from the hot water supply is turned on. This may be right under the kitchen sink. If it is turned off, just turn it back on and u should be set.
However, if you have water coming to the dishwasher but no water in the dishwasher it has to be one of two items:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Feb 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge pdw7880j10ss dishwasher lower roller fell off and melted on lower heating element. need to know part number of lower roller and plastic clip that affixes the lower roller to lower rack?
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Nov 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
Oct 13, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
234 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
