50PC5D UL I changed the panel out. LG sent a sub. I had to take psu and main board off of old set. They sent the correct cables for new boards. But now tv comes on 5 secs and shuts off. I did autogen and get good test patterns. LG sent me a new main board. Still shuts off after 5 secs. All voltages are good. What am I missing? There is one cable connected to P705 on main board but I don't know where it goes. LG cant help me. It is a 4 pin connector. Does it go to control board? There are two ports both 4 pin. Help.
  • Patrick McAlexander Sep 02, 2010
    This is a plasma
  • Patrick McAlexander Sep 07, 2010
    Thank you. You have been very, very helpful.
  • 12,061 Answers
I presume because you say "All the voltages are correct" that you must have a service manual?
http://www.retrevo.com/pdf/23138ag202/9/TROUBLESHOOTING/
Above is your troubleshooting manual, below is for a service manual, if you do not have one.
http://www.service-docs.com/store/L-O%20Service%20Manuals.html
Support link below.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=50PC5D-UC&matchedModelCode=NOT_MATCHED&searchEngineModelCode=50PC5D-UC&initialTab=warranty&targetPage=support-product-profile
Right whenever a unit shuts down after a few seconds, the problem is usually an Overload, on the Power Supply or an output from a high current output.
You need to use an oscilloscope, and/or a Multimeter and monitor the main Voltage outputs, and see which one is failing, and subsequently shutting down the PSU. Usually you are looking for a short circuit, or nearly so, and usually the bad component(s) will be very hot. Often the bad part can be isolated using Freeze Spray, one freezes components one by one, and restart, the one that you freeze and clears the problem, even if only temporarily, will be the faulty component.
Now if it is NOT a faulty component, it may be that the PSU, is NOT getting the signal that indicates All is well, after the Computer does a self check, when finished it then signal to the PSU, that all is OK, and to continue to Power on, now if there is a logic fault, missing signals etc, then the PSU is instructed to power down, to stop any bigger problems occurring.
You say all the voltages are correct, well this maybe so up to a point, but obviously, they all Cannot be all OK, as it still shuts down.
You need to use the schematic diagram, and take readings around the input, output connections, and check, that indeed the Voltages & CURRENT drawn is within spec. This can be a long and arduous task.
As for your errant connections, well again the ONLY place this information would exist is in the Service Manual. You MUST check, using the manual, that signals and waveforms are exactly correct.
many many problems are actually within the PSU itself, so this is a good place to start. Then check, the load, (Sub Circuits) that connects to the PSU's individual voltage rails, looking for the problem that causes the shutdown. usually, if a short or partial short, the Voltage on that Rail, will dip, or drop, immediately before failure, I usually use my oscilloscope in Capture Mode, to check.
As related using the service manual, and schematic, work, along the Voltage rails, measuring waveforms and voltages and currents, until you find the faulty, section or component(s). Which should be replaced.
Also remember may Faults are Chain faults, meaning that, one faulty bit, may lead top another, like say, a faulty diode, is allowing AC ripple to pass and this in turn makes an Electrolytic Capacitor go faulty, so just replacing either one will NOT fix it, one needs to find and replace BOTH.
Good luck.
Posted on Sep 03, 2010
    Sergeant:
  • 252 Answers
The connections you are talking about only fit a certain way they are mistake proof.Your problem is in the hig voltage section of your TV though check the ceramic caps they are usually connected in parallel. Next to a transformer. Your set has three circuits like this for each colour gun. Take one lead of the caps out of the circuit. If one is reading below the normal farad reading of all the rest this is your problem. Make sure you check them all.
Posted on Sep 01, 2010
LG plasma TV 50PC5D. Have to push the power button for over 12 times, especially if not used for a day. If just watched and turn off and turn on a minute later, the TV can be turned on with 1 click.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 31, 2016 | LG Televison & Video
LG 42LE5400 When i touch the power, al the keys come to life, but no backlight, I cannot see if the tv is booting, just see the lights on the control panel, any ideas?
Try a hard reset to this set first. If it do not help you, the main board to this set is damaged. Contact any service technician; if this is the case.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 31, 2015 | LG 42LE5400 42 in. LCD TV
Picture but no sound
Check its speakers first. If they are found OK, check and replace the audio output card. Check the voltage to this card from main power supply regulator board.
Jan 12, 2013 | LG 50PC5D Television
Lg 50pc5d
If picture only one side or only top or bottom set uses two boards to drive the screen, either one of them is bad or the actual display panel itself--it is the entire screen unit where the picture is displayed.
May 25, 2012 | LG 50PC5D Television
Image on LG 42PC5D-UL is off center toward right side of screen after replacing main board eax38589402 from LG 50PC5d-UL. Both boards have same part number.
You've got to go minto your main menu and in the screen position settings you will be able to correct the horizontal offset and the verticle offset. You'll also hve the option of resetting all values to factory default but, I would suggest the former first. Thanks, Dana
Jan 15, 2011 | LG 42PC5D Television
I have an lg 50pc5d it wont turn on, green light just keeps flashing
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Oct 21, 2010 | LG 50PC5D Television
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
LG Plasma 50PC5D Help
sounds like the internal screen has cracked look closeley to see if you can see any cracks if so new screen im affraid if no cracks suspect power board
Mar 20, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
189 people viewed this question
Top Televison & Video Experts
