Question about Nordic Track Nordictrack Apex 6500 Reflex Technology Treadmill
I need to move a treadmill from the basement to upstairs how do you break it down so it lays flat
Disassemble Toshiba 51H84 Does anyone know how to do this?? It died and I'm trying to remove it from my basement. Figured if I separate the screen and the cabinet, it will be easier to haul upstairs.
Well if you are not going to get it repaired it really doesn't matter how many pieces you break it down to. I am not being sarcastic. The cost to repair it might not be worth the effort.
Oct 15, 2016 | Toshiba Televison & Video
Ksrs271 refrigerator moved from downstairs to upstairs now not cooling
did you lay it down? if so it needs time to settle.
after switching off you might have to reset the temperature.
Sep 30, 2016 | Refrigerators
Hello there, I have a split entry home with a finished basement. I was wondering: on nice warm days, with a wind blowing through the upstairs, if I can leave my windows open upstairs while the...
Connie, it will only work if all of the interior doors to the basement are closed during this time. Even putting an old towel at the bottom of the door(s) leading to the basement will stop the air flow.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
I live in a three story house my wii is in the basement and my wireless router is on the second floor should my wii pick up a signal...i tried to hook up with netflix and my wii says cant find connection
Hi.
1. Try using it upstairs on the 2nd floor and if it works there you know its a range issue with the router.
To then solve it you could run a cable from the router down to the basement (which is a bit old school but very effective and guarenteed to work) or get a second router or modem and place it in the basement. (for modem you would need a phoneline in the basement)
2. If it doesn't work upstairs, make sure you have the correct connection information for your network and that your network is broadcasting its SSID. If your network is not broadcasting it is what is known as hidden. This means that you will have to enter all the network information manually by following the prompts on the wii console.
Jun 16, 2011 | Nintendo Wii Console
Need to dismatle to move and can't
There are a lot of different treadmills and stairways that require specific solutions, but there are some general solutions.
You say you can't disassemble it, so try forearm forklifts, they can make a 2 person lift very manageable. Also if you have a large piece of cardboard (and once again, 2 strong people) the cardboard can be used to both provide a surface that will slide up the stairs and distribute the weight over a larger area, so you can actually put it on it's side without causing damage.
I've used this technique and it works with a little caution and muscle.
Oct 17, 2009 | Exercise & Fitness
Digital channels will not tune
I reconfigured channels a couple of times and they started working. Thanks
Feb 08, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Tread will not move, shows a L 5 error code
You need a new lower control board. 225.00 from nautilus.
Dec 14, 2008 | Bowflex Treadmill Series 7
Nordic Track Nordictrack Apex 6500 Reflex Technology Treadmill Logo
167 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
