Question about NorStar Meridian M7310 Phone
I have tried but have been unable using feature #806 to cancel seeing the time date to seeing what is the number of the incoming call when i try to cancel it gives me invalid code. i have checked with the phone company and we have caller id i cant change anything as well as the person before who was fired programmed all 6 phones and did not tell anyone her passwords
  • NorStar Master
  • 2,460 Answers
Wow. First of all, did CID ever work? If you happen to have a CICS (Compact ICS system) walk to the system and look at the cards in the big tall slots. There will be a CI indication in the upper right side of the card to show that it's caller id (Part number in the center has NT75 in its part).
Start with that first. The installer password is in the installation manual. You can look around this forum to find if anyone has shared that password, but it's beyond the scope of a free forum for me to give out a password that can be used to destroy a system's program.
Carl
Posted on Sep 01, 2010
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
Toggling between greeting 1 and greeting 2
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Mar 11, 2010 | NorStar M7310 Corded Phone
A message saying call divert set pops up immediately after dialing a number, why is this and how do I fix it? I have an At&t LG Cf360
The Call Forwarding feature is activated. This feature allows you to direct your incoming calls to another number. Go to Menu>Settings>Call> Forwarding>All voice calls. Select Cancel/Deactivate to disable it. You have also the option to direct incoming calls if you cannot answer it, if the phone is in use, and/or if the phone is switched off or out of coverage.
Jan 24, 2010 | Nokia E71 Smartphone
Can I block one number for incomming calls and messages?
earlier this was possible.here r some codes just try them,
to activate NO ANSWER : **61*NUMBER*13#
to cancel #61*NUMBER*13#
to activate NOT REACHABLE: **62*NUM*13#
and some networks like vodafone already have these features. i dont know about other networks. if u use vodafone u can call the custumer care n they will do it.
Sep 08, 2009 | Nokia 8800 Sirocco Cellular Phone
No message light
Have you tried a FEATURE #806
Feature 806 means Static time and date, but sometimes it shuts off the message waiting indicator lamp???
Not too sure why, but give it a try.
Feb 25, 2009 | Nortel Meridian M7208 Corded Phone
DO not disturb feature will not turn off
do not pick up the headset
push feature 69 feature
Jan 20, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Where can i find instructions for using features Norstar M7031
The feature codes will not help you troubleshoot the system at all. But here you go:
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 08, 2008 | NorStar M7310 Corded Phone
Problems with norstar m7310 corded phone do not disturb feature
What do you want to change? What feature is programmed on the button?
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 02, 2008 | NorStar M7310 Corded Phone
NorStar Meridian M7310 Phone Logo
140 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
