Question about Canon PIXMA iP4600 Color InkJet Photo Printer
I have done the cleaning and the deep cleaning functions several times and I cannot get the thing to print. The 220 cartridge is fine, but all the colors are showing problems. I have been out of town for three weeks and the printer has not been used during that time. Does it matter?
  • 3 more comments
  • kevbevhiggin Sep 01, 2010
    I meant that I had only used the printer's program to perform a cleaning and a deep cleaning.
    Thanks for your response, but could you explain how to separate the print head? There is a medium grey bar that lifts up, but then I can't seem to lift the whole unit out of the printer.
    WOW! I actually cleaned the printer. I took the head out and ran it under warm water and dried it all out. BUT . . . now that I have it all together, the only color that is NOT working is the big black one - PGBK - and it isn't working at all. I took the cartridge out again and reinstalled it. I ran the deep cleaning program a couple of times for the PGBK only and I still have nothing coming out of it. Any thoughts?
  • kevbevhiggin Sep 05, 2010
    Sorry, But I am still having trouble with the printer. When I cleaned the print head with warm water, as you suggested, all the colours then printed fine. BUT the black (PGBK) now doesn't work. It was the only one that worked properly in the first place.
    So I cleaned the metal contact points as you suggested and now the thing is blinking at me. The error light is flashing 5 times. I have taken out the cartridges and print head several times and replaced it carefully. All the cartridges are full of ink. Now I am really starting to get upset, because I need to use the printer to be ready for classes that start on Tuesday.
    Can you help me?
  • kevbevhiggin Sep 06, 2010
    So! Here's what I did. Before giving up on this whole thing I took it all apart again, and cleaned the metal points and carefully but firmly put it all back together and now the whole thing is working fine.
    Thank you.
    Over and Out.
    Kevin Higgins
    Befor giving up on it, I took the whole thing apart again, cleaned it again, and put it all back together. Now it works fine.
    THANX
  • Canon Master
  • 4,737 Answers
Sometimes if cartridges are not used for a long period of time, their contacts got rust and will show cartridge problem, this could even lead to permanent failure of the particular cartridge/s. I don't exactly get when you say "I have done the cleaning and deep cleaning...." Do you mean you've cleaned the cartridges physically or have only cleaned them using the printer's tools? You need to clean them properly using cleaning materials like brush/cotton dipped in alcohol or acetone. Remove all the cartridges, clean the contacts (golden dotted circuit on the cartridge) and also clean the contact on the printer. Since your printer has a separate print head, it's important to clean the print head separately. Separate the print head and clean it with warm water so that clogged/dried inks will be cleared from the print heads (don't use brush or anything to clean the print head, you may damage it.).
After everything is cleaned and dried, reinstall them while you press the cancel button the the printer.
One more thing i've skipped, unplug the power cord while you clean the cartridges so that any static power will be discharged. Before you reconnect it to install the cartridges and to power it on, press the power button several times.
If this cleaning doesn't help, you'll need to replace them, but I hope it'll work for you.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 01, 2010
  • 3 more comments
  • Lebanon Raingam
    Lebanon Raingam Sep 01, 2010
    Well, I hope you know how to uninstall and install the cartridges, if so, that's what I mean. Remove the cartridges and pull out the print head from the compartment, there's a lock, you have to pull it aside to remove them. Anyway, let me give you another simpler tips. Remove all the cartridges, move the carriage (print-head holder) towards the left and place a folded Tissue paper/napkin in the middle of the carriage passage, now pull the carriage with the print head towards the position where the tissue is placed so that the print head will seat over the tissue paper. Take a syringe (without needle) with some water [the best cleaning material is the cleaning solution] in it and clean the head (one compartment at a time) by spraying the water on the print head. Continue this before you are sure that it's cleaned, you may need to replace the tissue several times:
    You can refer to this video:
    Not the same model, but the cleaning procedure is similar.
    Note: it's also important to place a plastic bag below the tissue paper so that the water will not flow down inside the printer.
    If you are not sure and if you doubt you might make mistakes with this, then better refer to the Manual (Page # 5-6). There you'll find how to install the print head, and in the same reverse method, you can uninstall the print head.
    You can download the manual from here (click here), Open the link, enter your email address in the first box and enter the text shown below in the second box and click "Download Now".
    Good luck.
    Once again, thanks for using FixYa.
  • Lebanon Raingam
    Good to hear that you've already done the necessary tasks. Do you have a cartridge refill kit? and another question, Are you sure that there's ink in the black cartridge?
    If you have a refill kit, first refill some ink and **** out a small amount from the head part (the portion that fits into the print head). If you don't have a refit kit, then try this, place a folded tissue or soft cloth on the tip where the ink comes out (head part), and **** it with the tissue or the cloth, if there's ink, it'll come out and you'll be able to use it. When a cartridge is not used for sometime, the ink got clogged and it never comes out until you force it to do so. It's also important to dip the tip in warm water (partially only to dissolve the dried ink), and clean it properly, now **** it again. You can reinstall it if ink comes out. If no ink comes then I don't think it'll be re-usable, you'll need to get another. But I wish you good luck.
    If you need my further assistance, let me know.
    Once again Thanks for using FixYa.
  • Lebanon Raingam
    I am sorry, there's a little mistake. A particular word is omitted by the system (considers it as spam or adult content). Let me use another term for that "use your mouth to draw out the ink" opposite work of "blow". :-) sounds funny.. but no choice.. Thanks
  • Lebanon Raingam
    Lebanon Raingam Sep 05, 2010
    I am afraid, there must be faulty with the Black Cartridge, which means it'll not longer usable. I know that you've tried enough with whatever you can but sometimes it's not possible with cleaning and maintenance, we need to replace the particular component/s. If it's blinking, then the cartridge's contact is no longer alive, we can do nothing with it and we can't repair it. The only alternative is to get a new one.
    It's unfortunate that it can't be fixed this way, but I hope you understand, I've also tried my best to help you fix it with my possible simplest instructions and easiest method, but I am sorry. I wish I could personally inspect it, but what can i do? You better search for another alternative to print the question papers.
    I could only wish you good luck.
  • Lebanon Raingam
    Lebanon Raingam Sep 06, 2010
    Woww... it's a great relief for me to hear that it works..
    Once again thanks for using FixYa.
My hp dj9000s printer is switched off since 6 month, now I switch on it shown error message for Lc, Lm ink cartridge. (cartridge is ok I replace with new one but error is same)
If an inkjet printer has not been used for some time and several print head deep cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 25, 2011 | HP DesignJet 9000 InkJet Printer
I have a Brother MFC-6490CW that my husband purchased for me somewhere between one and two years ago. I just recently decided to use it, and the black ink would not print. I thought the original...
Power purge the machine:
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Feb 25, 2011 | Brother MFC 6490CW InkJet Printer
Blue ink cartridge does not print
have you done a print to see what colours are coming through. sounds like the heads are clogged. try putting some meth spirits or similar in the cartridge to loosen things. I would use a syringe, it could be messy.
good luck
Aug 01, 2009 | Brother Multi-Function Center MFC-665CW...
Won't print in black.Colour is fine though!
your printer black cartridge is demage buy a new one
Jul 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Cannon mp830 prints all colors but yellow
Your print head is likely toast.
The only way to be sure is to test out your purge unit (aka capping assembly).
This assembly provides the suction when you use the cleaning function. One test is simply to install a new oem ink cartridge, do a bunch of cleanings and see that it is actually emptying the ink out of the cartridge (look in the cartridge and see that the ink is being used up).
Since you said you have tried several cartridges, I would hope this means you know 100% for sure that the ink level in the cartridge is going down (you cannot rely on the level indicator in your driver software).
Since your purge unit is working, then your print head is either so clogged that the purge unit isn't strong enough to clean it, or the print head is defective.
Remove the print head and inspect the bottom. Give the bottom surface (and no more) a rinse under very hot running water. Blot the bottom surface on paper towel and see if there is any yellow ink coming off in the paper towel. If you can find a tube that will fit over the yellow ink well in the print head (the part that contacts the ink cartridge) try and force water through the tube and see if a fine mist comes out the bottom of the print head. If yes, then the head is not clogged. If no, leave the print head to soak for several hours. A saucer with a small amount of water in it will do. Just let the bottom surface of the print head contact the water (the cap off of a can of spray paint usually works for this)
Let the print surface soak for a few hours, or even over night. Reinstall the print head and give it a deep clean. If it still does not work, call your local Canon repair shop and check the price of a replacement head.
Nov 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
All colors print blue
You did the right thing. Sometimes a bad printhead or a bad cartridge will cause a leak and will damage both. Good job!
Jun 05, 2007 | Canon i850 InkJet Photo Printer
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
507 people viewed this question
old marine
old marine
