Question about Electrolux Vacuums
My vacuum cleaner is an old model Electrolux L-E, serial number L37237F. I need to replace/repair the on/off switch on top of the tank. Where do I get the part(s) and how do I access it and replace it?
  • rcanderson2n Sep 01, 2010
    My vacuum cleaner is an old model Electrolux L-E, serial number L37237F. I need to replace/repair the on/off switch. The large switch ?push button? protrudes through the top of the tank housing. I can get the part(s) thru TotalVac.com.
    I probably have to replace the on/off switch housing Part: EXR-3438ES. How do I open up the housing of my model LE tank style to access the switch parts to determine what needs replacing? I?m a mechanical engineer by trade and I don?t see a way to open it up. It?s probably simple if I knew the secret.
  • 22,219 Answers
Wow my mum had one of them 50yrs ago ,worked well as i remember ,i think its just a push button on and off switch and to access the switch which was on the back end you pulled the bag out ,undone the nut on the switch and pulled it out ,it had two lucar connectors on the switch ,now something this old will be difficult to find so if you ask nicely in electrical wholesalers or similar iam sure they will find you a suitable switch ,ok its not the original but so long as it works ?? does it matter ,
Posted on Sep 01, 2010
  • 17,970 Answers
Try to looking here: totalvac.com/electroluxswitches
Also, reminder: Be sure that the replacement items for your products are genuine Electrolux parts. All genuine Electrolux replacement products are clearly identified on the outside of the package.
You can find genuine bags, belts and filters at the retail store where you purchased your Electrolux product. It is also easy to order authentic Electrolux items through our On-line Store. We are happy to ship directly to your home (U.S. and Canada orders only). If you aren't sure what you need, please call our order fulfillment center toll-free at 1.800.896.9756 between 8:00 a.m.-7:30 p.m. CST Monday through Friday, 10:00 - 6:30 Saturday.
Hope helps.
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
Electrolux Epic series 3500 model Upright Vacuum cleaner motor(replace old one)?
I don't know what your question is, but replacing a motor for Electrolux, now Aerus, should be done by an authorized Aerus Electrolux service tech. The uprights are especially tricky to take apart and reassemble correctly. The address and phone number of the Aerus store/service center nearest you can be found at the site below.
http://www.aerushome.com/storelocator/
Mar 13, 2011 | Electrolux Vacuums
Vacuum cleaner won't turn on. "On" switch is broken, but it has been turning on by just plugging it into a socket. Plug symbol now lights up on tank and machine doesn't turn on at all. Is it a...
It sounds like you may need a new switch rocker arm. If so this is not an expensive repair. I would suggest you takeit to a reputable vacum shop for repair.Chris
Feb 20, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
I have a 20yr old electrolux central vac that the motor just went bad. in wondering whether to replace motor or replace whole unit i have found an electrolux unit and a aerus unit. someone told me elect....
Motor to replace or rebuild:
Depending if your motor just started to get noisy, you can take it to a private vacuum repair shop and most rebuild for around $80 to $100.00. Usually they replace top/bottom bearing and the armature carbon brushes.
If it's loud and vibrating and probably sparking. Do not bother to rebuild, the armature is now probably damaged and not worth the new parts.
Replacing the motor is pretty basic and usually saves you about $150.00. They're pretty simple to release out of the unit and are pretty simple to remove and reinstall.
To find out your replacement motor number you will need to find the stamped model number on the motor itselt. It is a 6-8 digit number. That is the Ametek Motor Model number. Ametek is used in pretty well all central vacuum systems. Motors range from $99 to $239.00
www.ametekfsm.com/Product_Compare.aspx?MT=1&MST=1&FanStyle=Bypass&Discharge=Tangential
Dec 30, 2010 | Electrolux Centralux Vacuum
The agitator brush of my central vacuum cleaner didn't roll.What's the problem of it?
If the power nozzle motor is running, then the problem is a broken belt. It's recommended that it be taken to an authorized shop for replacement.
If the PN motor is not running, locate the reset switch on top of the PN and depress. If the motor still does not come on, there's a problem in the wiring or power module. The entire machine, including hose, wands, and power nozzle needs to be taken to the nearest authorized shop for exact diagnosis and repair/replacement of parts.
If the machine is the old style Electrolux (now known as Aerus), not sold in home improvement stores, the nearest authorized store can be found on the below site. Just follow the instructions.
Dec 07, 2010 | Electrolux Central Vacuum
PLASTIC HANDLE RELEASE BROKEN. WHERE DO I FIND A REPLACEMENT?
Greetings from GoVacuum.com,
We are a vacuum cleaner parts store, http://www.govacuum.com, and we carry parts for over 40 different brands of vacuum cleaners.
We almost certainly carry the handle release pedal for your vacuum cleaner. If you'd like to leave your vacuum cleaners brand, and model number (can be located on the back or the bottom of the vacuum cleaner on a sticker that will also contain the serial number), I would be more then happy to help you not only find the part you need, but also explain to you how to install the part.
Please feel free to click on "Clarification Request" here on Fixya, or send me an email to chris.jones@govacuum.com.
I look forward to helping you find the correct part for your vacuum cleaner, Please vote this repair as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of this repair.
Thank you so much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Vacuums
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux 2100
Call your local Aerus Electrolux office. If there is a problem in the electrical system you should get that checked before you continue with the machine. As for the cord replacement- Any Aerus service dept. can do that for you. I say an Aerus office because should you let a non-Electrolux employee work on it you will void your warranty.
Dec 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Repair
In your owner manual there should be a number you can call for service. If less then a year old, then it is under warranty.
Nov 07, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
223 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
