Question about Kenmore 63942 Dryer
I have kenmore front load dryer. wont do anything when you turn it on. was working fine then just stopped. is getting power. what could cause this?
    Problem Solver:
  • 12 Answers
Check thermal fuse located in back panel. make sure power is unplugged before removing cover. thermal fuse is located near exhaust and it's coated with white plastic with 2 leads sticking out. with volt meter check for continuity, no continuity must replace thermal fuse, it cannot be reset.p.s. remove wires from fuse to get accurate reading.
rwpfn@aol.com
Posted on Sep 03, 2010
I have a kenmore front load dryer model 61292010 just stopped working no vents are blocked breaker is working fine is there anything else i can ckeck
Check your handbook for a thermal overload that needs resetting. Its probably down the back out of sight?
Aug 05, 2014 | Kenmore Dryers
Kenmore 89722 dryer
check the micro switch on the door . worn door hinges/broken door hinges will not activate the micro switch and so the unit will not turn on as it thinks that the door is still open
Nov 11, 2013 | Cars & Trucks
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
Kenmore dryer wont start tab broken
Yes that is the lever for the door safety switch. It can be fixed easily,
I have repair pictures and home made video on Kenmore dryers HERE
Dec 02, 2012 | Kenmore Dryers
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Kenmore 63942 Dryer Logo
99 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
