Question about Alpine CDA-9856 CD Player
Need to remove the unit, and I do not have the unlock keys how do I do it or do I need a key to remove it
  • Alpine Master
  • 4,848 Answers
Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire
coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These
can be unscrewed using the appropriate size of Allen key.
Posted on Sep 01, 2010
I have lost my smart remote key for my Mazda CX-9 2011. Can I program a new one myself?
You may need 2 keys to do this, possibly just one. My source does not specify if 1 key will work but here is the procedure i found
With two programmed advanced keys
  1. Bring the programmed advanced keys (2) and a unprogrammed advanced key into the vehicle.
  2. Close all doors.
  3. Insert the supplementary key into the ignition key cylinder. NOTE:
  • Complete the procedures up to Step 7 within 30 s after the supplementary key is inserted.
  1. Turn the ignition switch to the ON position.
  2. Press the UNLOCK button on advanced key 1.
  3. Press the UNLOCK button on advanced key 2.
  4. From the ignition switch in the ON position, switch the ignition switch in the order indicated below.
  • ACC->ON->ACC->ON->ACC->ON
  1. Open the driver-side front door, press the door switch twice , and then close the door. NOTE:
  • After Step 3 is completed and the advanced key programming mode is activated, the door lock actuator operates to lock, and then operates to unlock.
  • If the door lock actuator does not operate, repeat the procedure from Step 2.
  1. Press the UNLOCK button on the unprogrammed advanced key twice . NOTE:
  • After Step 8 is completed and the advanced key is programmed, the door lock actuator operates to lock, and then operates to unlock.
  1. If programming more advanced keys, remove the supplementary key once, and then repeat the procedure from Step 2.
Aug 04, 2016 | 2011 Mazda CX-9
Remote entry keyfob control doesn't work. Batteries are good.
Unfortunately theres not a lot you can do with them. If you are sure the battery is OK and the contacts are clean and it still doesn't work then a trip to the dealers to get it reprogrammed or replaced is in order.
Can you see any moisture inside? any chance you dropped it in the rain by accident?
If by any chance it has come into contact with moisture try drying it out somewhere warm but not hot as that may cause more damage.
Aug 08, 2008 | Jaguar XJ8 Cars & Trucks
Ford edge alarm sounds when key used to start car
sounds like the alarm needs resetting , look in the owners manual for the procedurer,might even just need a new battery in the key/fob unit
Jul 24, 2014 | 2007 Ford Edge
Wrwent to unlock my 1996 Hona accord with the remote and noticed the light was on. It wouldn't unlock the door . Put in a new battery and that didn't work. Do I need to reset the alarm? If so, how do I do...
Remote Transmitter Replacement (Wagon)
Use the following procedure when replacing one or both remote transmitters:
  1. Open the driver's door.
  2. Press and hold the driver's master door lock switch down in the UNLOCK position.
  3. Quickly insert and remove the key from the ignition switch five times, then insert the key the sixth time, and leave it in the ignition switch. (This routine must be done within 1O seconds.) All the doors will lock and unlock to indicate that the control unit is in the program mode.
  4. Press either button on the replacement transmitter. All the doors except the driver's door will lock and unlock to indicate that the control unit has accepted the transmitter into its memory. If either transmitter button is pressed again, all the doors will lock and unlock.
  5. To program a second transmitter, press either button on that transmitter. The doors should lock and unlock as described in step 4.
  6. Release the driver's master door lock switch.
  7. To exit the program mode, close the driver's door or remove the key from the ignition switch.
Dec 18, 2010 | Honda Accord Cars & Trucks
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
Deadbolt wont unlock
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Jan 09, 2010 | Kwikset Brz Sgl Cyl Deadbolt
My Storms locks looking for unlock key, where is the unlock key?
The lock key is located at the at the very top of the unit, on the left hand side as facing. This is a very frequently asked question, and not a very good design element on the BlackBerry Storm.
Jun 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
Removing alpine receive from dash
Unless you have the 'keys' that came with the unit, you'll need an Alpine dealer to a) get keys so you can remove yourself (wiring just un-plugs) or b) installer. CStereo mfgrs use different snap-lock mechanisms and sometime different keys for different models.
Apr 21, 2009 | Car Audio & Video
How to program the key for my bmw 750i model 1997 to lock/unlock the door
BMW 7-Series - Key Remote Programming
Three methods to try:
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
window.google_render_ad();
Dec 16, 2008 | BMW 750 Cars & Trucks
Alpine CDA-9856 CD Player Logo
196 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
