Question about HP LaserJet 3015 All-In-One Printer
I have installed the printer directly to my note book and an error shows instead of ready
  • pratima_s Sep 01, 2010
    I downloaded the driver but the error message is still there
  • HP Master
  • 17,130 Answers
Remove the software after disconnecting the printer and then reinstall the software, make sure no other conflicting softwarre is present. Now reinstall and check.
If not the OS can be faulty
Posted on Sep 01, 2010
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Difxdriverpackageinstall error 10
I am getting the error (DIFxDriverPack ageInstall Error = 10) message when trying to install my Brother MFC-J625DW printer. Is anyone else getting this? Any workarounds? I've tried re-installing the drivers and get the same error! thanks.
Aug 30, 2012 | Brother MFC 6490CW InkJet Printer
My Mac Book Pro is showing an error when I print
Throw away your HP disk and delete all HP software installed on your machine. It's quite rubbish.
Go to system preferences, and printers. Remove your HP printer (by selecting it and clicking on the '-' Then click on the '+' and let OSX find your printer and automatically load the driver. Now it will work.
Jul 16, 2010 | Apple MacBook Mac Notebook
My printer gets stuck on initializing...or calibrating. I have unplugged, rebooted and have gotten it to say "ready" but still will not print.
After you power on the printer, does it ALWAYS do calibration, and if so, does the calibration cycle complete or just goes on and on?
From your description, it sounds like the printer will come to the READY ... eventually after calibration. That's a good sign. The fact that it does not print could be other factors.
1. first, get a high speed parallel cable and hook the printer directly up to your computer. Be sure your commnications are good.
1a. if you only have ethernet connection to the printer, then you'll need to print out the information page so that you can find the IP address of the printer. If the printer's IP address shows all zeros, then the IP address for the printer's jet direct card has not been defined. Instead of going on about how to install a new port, drivers, etc. please tell me where you're at.
Jan 06, 2010 | HP LaserJet 4600dn Color Printer
Printer won't print labels
Try resetting the printer:
Note: it will erase all network settings.
Turn the printer off, press and hold the GO button, turn the printer back on, continue holding the GO button for at least 10 seconds, but for fewer than 20 seconds. After the Go, Attention, and Ready LEDs turn on, release the GO button. During this process, the Attention LED will turn on, the LEDs will begin to cycle, and the unit will perform a cold reset until the printer returns to the Ready state.
NOTE: If either the Go or Ready light turn off or no LEDs turn off before the GO button is released, repeat the process.
For PCL XL error: try to reinstall the printer drivers.
Oct 11, 2009 | HP LaserJet 2550L Printer
Hp laserjet3030 is put on it shows" Scanner Error"
Hi ritaccpl: Here is your problem. 52 Scanner Error The all-in-one has experienced an internal hardware error. 1. Turn off the power by using the power switch, and then wait at least 30 seconds. 2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket. 3. Check the FFC connection between the formatter and the scanner. NOTE Do not bend or fold the FFCs during the removal or reinstallation process. 4. Try connecting the product to a different power source or surge protector. 5. Turn on the power and wait for the all-inone to initialize. 6. If the error persists, replace the laser scanner assembly. Hope this helps
Jun 08, 2009 | HP LaserJet 3030 All-In-One Printer
Printer not printing
Formatter internal RAM or ROM error.
Apr 23, 2008 | HP LaserJet 1200 Printer
HP LaserJet 1300 is showing blinking of orange light instead of tonner is in
I am having problem in finding solution for HP Laser Jet 1300 which is not getting ready and shows orange light blinking. I have check the tonner and the sensor which are located backside but the problem is still as it.
Apr 11, 2008 | HP LaserJet 1300 Printer
Inaccurate error message
According to Canon's website:
Details Print Friendly Version Issue: ERROR LCD: More than one ink tank of the following color is installed U071
Solution: Replace defective ink tank (MP500 / MP800)
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.).
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press the ink tank's tab (1), then remove it from the slot (2).
  5. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Aug 14, 2007 | Canon Pixma MP500 All-In-One InkJet...
HP LaserJet 3015 All-In-One Printer Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
