My AVEIS TV keeps turning off by itself after an hour or so
Aveis tv parts
Check where you bought the TV if that don't work check with the manufacturer. Then look on internet, Base for a Aveis TV.
Aug 13, 2013 | Televison & Video
Need remote code for Aveis tv
036,018,022,038,071. Check these codes. If you wish to get more codes, check this link.
Feb 27, 2013 | Televison & Video
Don't know how to change the picture size on my aveis tv
If it has a aspect button on the remote that will work--some formats screen aspect is fixed and cannot be changed.
Dec 03, 2012 | Televison & Video
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
Need a code for an Atlas PVR universal remote control on a 32 in. Aveis flat sreen tv or to know who makes Aveis tv. Thank you!
Aveis is a daytek product which is a Daewoo company. I found a site where you can check and make sure of this http://www.daytek.ca/ Click on products. I found codes for daewoo on page 35 of a manual I downloaded from this site:http: //tv.manualsonline.com/manuals/mfg/shaw/atlas_pvr_universal_remote_control.html . I hope this works for you.
Oct 06, 2010 | RCA Universal Remote Control
Have an Aveis TV and an RCA universal remote. Need
There is no code for the Aveis Tv in the code list but you can try doing this for code search...
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 04, 2010 | Televison & Video
Aveis LT15AP3
AVEIS LT15AP3; WHEN CHANGING THE CHANNEL BY LAST CHANNEL OR BY PUTTING IN ACTUAL CHANNEL , IT DOES NOT CHANGE TO CHANNEL I PUNCHED IN BUT TO CABLE CHANNEL 3. IF I TURN TV OFF AND HAVE THE CHANNEL I WANT ON, IT COMES ON THAT CHANNEL. THEN IF I CHANGE CHANNEL IT GOES BACK TO CHANNEL 3. HELP????
Apr 14, 2010 | Televison & Video
Codes for aveis tv for remote
My Aveis remote does not have a code on it,in order to for Bell Express to program my remote for the receiver they need to enter the code into their system first,can you help ?
Mar 15, 2010 | ASUS Televison & Video
My Aveis lcd flat screen has sound but no picture???
sounds like your picture bulb has blown!! not good they are very pricey!@ they only have so many hours so turn the tv off when you are not watching hope this elps ,, good luck!
Oct 22, 2009 | Televison & Video
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
