Question about LG Televison & Video
I have a LG -LCD TV , model RY-23lz21 , 22'' TV . There is a 2' bar of static going thru every picture. How can I fix this myself? Maureen
  • 6 more comments
  • moeaddin Sep 01, 2010
    what is an IC (integrated chip) and aproximately where would I find It?
    Maureen
    on the green circuit board?
    I can't seem to locate it. I have taken the back panel off. There is a green ciruit board. Is it on there?
    Thank you. I will download a service manual.
    Maureen
  • moeaddin Sep 02, 2010
    I finally found the IC chip. There does not appear to be anything wrong with it. Banged on it and I still have the same problem. Any other suggestions?
    I have a blue column of static going through my picture. How can I fix this?
    thank you. I will work on getting a quote.
  • moeaddin Sep 07, 2010
    How would i know if the capacitor has leaked and what is the SMPS power supply. Where would i get a new capacitor from?
    Thanks
    Maureen
  • LG Master
  • 17,130 Answers
Checck if there is a capaccitor that has leaked in the SMPS power supply section. If the filter capacitor is weak this ripple of noise can come over.
Similarily the same noise can come from the secondary section , so check or replace suspected capaccitors.
finally check for any grounding issues of the chassis or the shield of the HT sections, thee input sections.
Tighten all grounding screws or PCB ground.
Any dead insects inside can also cause a bridge in circuit and bring in these noise bars.
Posted on Sep 03, 2010
  • LG Master
  • 11,800 Answers
If the bar is there whatever the source of the image (tv, cable dvd player, all) then the fault is in the image processor located on the mainboard - it's buffer memory is defective and the data stored in one block is corrupted so it's displayed as static.
The mainboard to which the processor is soldered must be replaced. This is a job for someone that has at least basic experience of electronics. And you need to find a replacement board cheap enough to worth its replacement get a quote from the local LG repair shop, it might just not worth it.
Posted on Sep 02, 2010
  • 11,896 Answers
Remove the back panel of the tv. You will see an IC (integrated chip) Check the solder joints on the chip. Make sure none are loose or are seperated from the contacts. If they are, put some new solder on them for a good connection.
If the solder joints are good, and there are no burn marks on the circuit board and no swollen parts, then try gently tapping on the on the chip. This sometimes gets it to react properly.
Posted on Sep 01, 2010
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Sep 01, 2010
    It will be on the main circuit board.
  • Nate Stansfield
    Yes it should be on the circuit board. Sometimes they are also square instead of rectangular. If you google Integrated Circuit Chips, you can see different styles of them.
  • Nate Stansfield
    You can also download a service manual which may help.
    www.free-service-manuals.com
    www.retrevo.com
    www.schematics.me/model_list/tv/lg.html
  • Nate Stansfield
    I believe it will help greatly. I have to use them myself. They are hard to find, but you should see the links I provided which will lead you to the manuals. If you need anything else, let me know.
  • Nate Stansfield
    Nate Stansfield Sep 07, 2010
    Leaking capacitors are usually swollen. Sometimes but not always, there may be a burn mark on the circuit board. partstore . com and shop jimmy and another sites will carry them.
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
I have a 15 inch TV LG Smart TV something went out on it what could it be the model number is 50LN5700UH the LG light comes on but no picture
LG TV : Picture not coming on screen, but TV is on. - Forums - CNET
www.cnet.com > Forums > LG
CNETJul 14, 2014 - Dear All, Have a peculiar problem with my LG flat screen TV. It stopped working suddenly, that is no picture when switched on, I noticed the ... However, in my case the RED light keeps on blinking and there is a ticking sound ... LG Plasma Flat Panel 42PC3D - No picture just sound
Jun 11, 2015
No Picture from LG 50PS60 Plasma TV
Nov 16, 2013
More results from www.cnet.com
? 5:29
Jan 25, 2013 - Uploaded by Tampatec Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... came on good with green light working properlybut still no picture.
Oct 20, 2015 | LG Televison & Video
Sylvania lc320ss8 horizontal bar discoloration
Do you have tv repair exp. If not then take it to a shop.If you do then reseat the plugs on the T Con board ( Timing Control). If that don't fix it then go on E-Bay and get a price on a used T-Con board and try that. Those boards have a high rate on going bad.
Jan 13, 2014 | Sylvania LC320SS8 32 in. LCD Television
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Insignia 27 LCD tv that got a small static shock, now no picture.
try unplugging the tv for an extended period of time.(30-60min) plug it back in, that should do it, if not it may need a new power supply,
Dec 26, 2008 | Televison & Video
Lcd tv no picture
This sounds like a bad PC board. Your last resort is to pull the plug and plug in after 1 minute, and hope this resets the main board. It cannot be home serviced if you do not have the right spare parts.
Aug 21, 2008 | LG 42LC2D 42 in. LCD HDTV
My rca tv model # f27442 serial # bo54b2095 is having problems.
i have a brand new lcd will u sell me ur box as is and how much i am in melbourne australia
Jun 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
91 people viewed this question
Computer Repairing
Computer Repairing
