Question about Garden
1970 B/S 300421 engine. I can not get spark through the plug. I have tested with known good plugs, I can get a good buzz from holding teh plug wire, but can not get a plug to fire. Still runs on points/ condensor/ magneto
  • 97 Answers
SOURCE: 19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Posted on Mar 17, 2009
woobie dog
  • 1273 Answers
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Posted on Jul 19, 2009
SOURCE: no spark at spark plug center of Coil
2000 ford escort ZX2. 4cyl . No spark at the spark plug. Wires are good.
Posted on Aug 29, 2009
  • 47 Answers
SOURCE: no spark at plug
look for a light color coating on the parts if there is clean it off with sand papper check under the cap to
Posted on Nov 03, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
Huskee LT4200. Turns over. Why won't it start?
Any combustion engine needs 3 things to run...Spark, Fuel, and compression. You need to figure out what you are missing. Easiest thing to check is spark. Pull the spark plug and hold the metal base against metal engine casing, and making sure you are holding onto the insulating rubber of the boot, have someone help crank the engine over while you hold the plug there. Look for a good strong blue to white spark at the plug gap. If you have no spark or weak yellow to orange spark you will need to look into the ignition system. New plug is the cheapest and easiest thing to change and test again. If it is still a weak spark then you will need to look to the coil/ ht lead, igniter box, or pick-up. While the plug is out, you can check for compression in the cylinder. If you end up having good spark and good compression then you look to the fuel system. If you can't find a problem with your fuel system, your fuel, spark, and compression also have to happen at the correct time....so you check your timing marks. Simple steps of engine trouble shooting.
Jun 30, 2015 | Cars & Trucks
Test the ignition coil without just replacing gx390
Without an ignition coil tester the only it to disconnect the kill terminal of the coil and test by cranking the engine. Before you do this try a known good spark plug as they do fail.
Feb 04, 2015 | Garden
How do i test to see if the spark plugs are fireing
Hi Anonymous, remove spark plug wires off of plugs, leave spark plugs in heads. Use a 3rd known good spark plug to check for spark.
Insert 3rd spark plug into any spark plug wire, ground the threads on bare metal like the edge a cylinder fin. Turn ignition switch on and make sure run/stop switch is in run position and the bike is in nuetral. Hit the starter button and watch for spark. Good luck
Mar 28, 2014 | 2005 Harley Davidson FLSTSC - FLSTSCI...
2005 Jeep Cherokee miss fire on fifth cylinder
Pull the spark plug to see if it is oil fouled, preventing firing. If it is, you may have a mechanical problem in cylinder 5- do a compression test to check for low compression in that cylinder.
If plug is clean or only showing black sooty deposits from unburned gas, the problem could be either in the secondary ignition (plug, plug wire, coil), or an injection problem. Try a known good spark plug and spark plug wire, also a known good coil, if plug and wire wasn't it. If checking for spark, you need to see a blue snapping spark when cranking engine to verify good ignition. A weak or orange spark, or intermittent spark is an ignition problem.
To check injection circuit on number 5, you can purchase an inexpensive "noid light" at parts stores. It plugs into the injector connector, and if circuit is good the noid light will be blinking when cranking the engine over. It is rare for injectors to fail, but if circuit is good and no gas is getting into the cylinder, injector may be bad or plugged.
Good luck.
Oct 13, 2013 | Jeep Grand Cherokee Cars & Trucks
Had my truck tested,it said cylinder 1 misfire.what is causeing this?
Possible causes: bad spark plug, plug wire, coil, injector not working or stuck-clogged, or an internal mechanical problem where compression is lost on #1-like a bad valve not seating, or head gasket...To check for a mechanical condition, do a compression test.
First thing to do is pull the spark plug and check it or swap in a known good one. Check the spark on #1-should have a blue snapping spark when the engine is cranked. If so, not the coil or the wire. Keep looking. Good luck.
Sep 26, 2013 | 1997 Dodge Dakota
Van cranks but will not start
Hi, if the engine cranks over normally when you attempt to start you car, but the engine does not start, the problem may be NO FUEL, NO SPARK or NO COMPRESSION. The engine needs adequate fuel pressure, a properly timed spark and normal compression to start.
To find why the engine won't start, remove the air inlet tube from the throttle body, push the throttle open and spray a small amount of aerosol starting fluid into the engine. Crank the engine. IF it has spark and compression but NO FUEL, it will start and run a few seconds before dying. If it does NOT start, it probably has NO SPARK.
Another method to check for spark is to pull a spark plug wire off of a spark plug (if it has plug wires, coil-on-plug ignitions do not) and place the open end of the plug wire near a metal surface on the engine. Have a helper crank the engine while you watch for a spark. DO NOT hold the wire while doing this as it can shock you. If you see a spark, the problem is not spark, but most likely NO FUEL or NO COMPRESSION. If you do not see a spark, the problem is in the IGNITION CIRCUIT.
Proper fuel pressure is critical for fuel injected engines to start and run. You should hear the fuel pump inside the fuel tank buzz for a couple of seconds when the ignition is turned on (no buzz means the pump is not running and the engine is not getting fuel). You can smell the tailpipe for gasoline vapors after cranking the engine. If you smell gas, the problem is likely not fuel but NO SPARK. You can also remove the plastic cap and press the schraeder valve test fitting on the fuel rail to see if there is any fuel pressure to the engine (not a very accurate test because fuel pressure must be at a certain level for the engine to start, for that you need a gauge). Even so, no fuel at the fuel rail would tell you fuel is not getting to the engine.
Dec 22, 2010 | 1996 Chrysler Town & Country
Well my car wont start,tryed new battery still doesnt start. trey to pop the clutch didnt start. what could it be?
1) To find why the engine won't start, remove the air inlet tube from the throttle body, push the throttle open and spray a small amount of aerosol starting fluid into the engine. Crank the engine. If it has spark and compression but NO FUEL, it will start and run a few seconds before dying. If it does NOT start, it probably has NO SPARK.
2)Another method to check for spark is to pull a spark plug wire off of a spark plug (if it has plug wires, coil-on-plug ignitions do not) and place the open end of the plug wire near a metal surface on the engine. Have a helper crank the engine while you watch for a spark. DO NOT hold the wire while doing this as it can shock you. If you see a spark, the problem is not spark, but most likely NO FUEL or NO COMPRESSION. If you do not see a spark, the problem is in the IGNITION CIRCUIT.
3)Proper fuel pressure is critical for fuel injected engines to start and run. You should hear the fuel pump inside the fuel tank buzz for a couple of seconds when the ignition is turned on (no buzz means the pump is not running and the engine is not getting fuel). You can smell the tailpipe for gasoline vapors after cranking the engine. If you smell gas, the problem is likely not fuel but NO SPARK. You can also remove the plastic cap and press the schraeder valve test fitting on the fuel rail to see if there is any fuel pressure to the engine (not a very accurate test because fuel pressure must be at a certain level for the engine to start, for that you need a gauge). Even so, no fuel at the fuel rail would tell you fuel is not getting to the engine..
Thank you !!
Jun 01, 2010 | 1996 Nissan Maxima
My car wont start
If the engine cranks over normally when you attempt to start you car, but the engine does not start, the problem may be NO FUEL, NO SPARK or NO COMPRESSION. The engine needs adequate fuel pressure, a properly timed spark and normal compression to start.
Thank you !!
May 30, 2010 | 2002 Cadillac Deville
Car wont start
Thank you !!
May 19, 2010 | 1989 Oldsmobile Delta 88
1997 Jetta: glow plugs not working. Glow plugs tested good, ne...
Before you invest in a long drawn out Glow Plug replacement etc. A little known issue occurs on the ALH TDI engines. The temperature sensor sending unit. A small blue module that plugs into the coolant hose assembly will cause a P error on the glow plugs that is nothing to do with the glow plugs at all. The part fails and sends a temp error to the engine computer. I tested all the coolant glow plugs, engine glow plugs and glow plug harness and all worked fine. One of the test procedures for the glow plugs is to undo this sensor that will force the glow plugs to come on no matter what temperature. This confirmed my GP system was functional and the sensor was bad. I purchased the part from local VW dealer for $33 US and installed and it is fine. Dependent on your model it can be square or round. The link to this part for your car is http://www.partsgeek.com/catalog/1997/volkswagen/jetta/body_electrical/water_temperature_sender.html
Be sure to have VW Pentosin coolant on hand to refill coolant system as you will lose quite a bit when removing this part. It is located slightly behind the coolant glow plug assembly.. This is the round ones not the ones on the engine block at top.
Be sure that when you replace it you put in a new rubber gasket seal.. its a round rubber seal that should come with your new part. Dont reuse the old one or you will have a leak.
There is a c-clip that holds this in the hole you slide that clip off and wiggle the sensor out. Coolant will run out of the hole, so do this outside. The sensor is easily pulled out. You will need to insert the new part in teh same hole with new rubber gasket and replace c clip. Then plug in wiring harness and you should be good to go.
May 17, 2010 | 1997 Volkswagen Jetta
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
