Question about Ruud Central System Air Conditioner
I have a Rudd Model # vaka-060 jsa Ser # 4987f18935948 . Can you tell me what ton unit this is? Thanks Philip
  • 107 Answers
By this model number the 060 stands for 60,000 btu's and that converts to 5 TON..
Posted on Sep 01, 2010
What ton is rudd ser #4991 m3494 115
If you look in the manual it will give you BTUs divide that number by 12,000 that will give you the tonnage. Go to: http://www.ruud.com/products/heating_and_cooling/air_conditioners/ the Ruud website and look up your model more information is needed.
Aug 24, 2014 | Heating & Cooling
How many tons is a rudd model ubhc-14j06sfd?
I believe the "06" in the model number has been reversed. It should read UBHC-14J60SFD. This would make this unit a 5 ton unit. I hope this helps:) Have a great day!
Jun 18, 2014 | Ruud UBHC Air Conditioner
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
How do i know the tons and seer of my york unit model h4db060s06a ser #wglm032b12
That is a 5 ton system but I do not know the SEER rating. See that 060 in the middle of the model number? That means 60,000 BTU or cooling capacity and that is 5 tons.
Jun 20, 2011 | Carrier 38CKC042 Air Conditioner
I am trying to replace my old bryant heat pump with a new bryant heat pump, but I am having a difficult time figuring out the tonage. Can you tell me if I have the model number?
yes just post the model number and someone will be glad to help you..
fyi if the model number has for example 373036 373042 373048
the o and number after it usually is the btu value...
12000 btu's = 1 ton so a 036 would be a 3 ton 042 3 1/2 060 would be a 5 ton
post the number someone will help you out... another way to find out
carrier which makes bryant units can help you also
a number for ft. worth location is 817-834-4496 good luck to you
Feb 10, 2011 | Heating & Cooling
Need to know how many tons this AC unit is
To find out the tonnage, I would need to see the model number. If you can go to the out door unit and write down the number or look for this in the numbers and letters. There are 12,000 btu's per ton of cooling. I don't know if you have a central unit or a window unit, but look for numbers like this. 018, is a 11/2 ton, 024 a 2 ton, 030 a 21/2 ton, 036 a 3 ton, 042 a 31/2 ton, 048, a 4 ton, they don't make a 41/2 ton, and it go's to 060 a 5 ton. This is the largest for a residential that is made. From there they make units for commercial buildings that start at 71/2 tons up to 350 ton's on 10,000' warehouses for wine storage and so on. This is larger then a train box car. You may want to write this down and keep it as most people have no idea how to tell, and now you do. Please don't forget to rate me as I know you will be kind. Let me know if you need my help for any thing.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Sep 08, 2010 | Heating & Cooling
Does not seem to be sufficient cool for a 1600 sq ft manufactured home coming from the Coleman unit installed. Some vents more air, others less air. Unit runs without stopping ever. Can you give us some...
Hi John, depending on the size, I would need the model number from the outdoor unit if it is a split system, you should have 400 cfm per ton of cooling. If you have a 1600 SQ' home, and a 3 ton unit, 3 x 400 cfm is 1200. It would be to small. There are 12,000 B. T. U.'s of cooling per ton. 2 tons would be 24,000 b t u's. 3 tons would be 36, 000 b.t.u.'s. Also, most contractors put lever dampers in the duct work that can be adjusted. They will put a red flag where the lever is and we can adjust the flow to balance out the house. I don't know where your ducts are, under or above, but with a good light find the crawl space and check it out. Get the model number and call it in to get the tonnage or send it to me and I will tell you. It will have a 024, 030, 036, 042, or, 060 in the number, MODEL number and figure like I told you above, 12,000 per ton. 060 would be a 5 ton. This will let you know if the unit is the right size or not. Please rate me on this and I know you will be kind. Thank you John.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS CFM is cubic feet per Minute.
Aug 05, 2010 | Coleman Heating & Cooling
Trying to figure out how many tons our outdoor unit has
If you see any of these numbers that is your tonnage:
018= 1.5 tons
024= 2 tons
030= 2.5 tons
036= 3tons
042= 3.5 tons
048= 4tons
060= 5tons
Jul 15, 2010 | Goodman Heating & Cooling
How many tons is the Rudd Model UHQA-0818b air handling unit.
Of the info I could find online, this would be either a 1.5 or 2 ton air handler. This information was obtained from the website below. Hope this helps
http://www.allstyle.com/casedUncasedimages/Uncased.pdf
Apr 01, 2010 | Heating & Cooling
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Ruud Central System Air Conditioner Logo
150 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
