Question about Humminbird XNT Transducers XNT 9 20 T Mounting Unit
My Matrix X25 used to function correctly but it gives me now erratic depth readings and at times get paralyzed on a 7 or 8 meters reading? The auto test indicates that the sounder is OK I checked the power supply and (visaully) the cables.Can the transducer be at fault ? I am playing as an amateur with electronic and I own an oscilloscope. I am playing with the idea to test the Display unit at Home (the transducer is a below hull type on a sailboat) to check at least the emissions and the frequencies but I assume that I would have to replace the transducer with a dummy load. Would a simple resistor do and of which value, else which impedance should be the transducer ? Many Thanks my email address is jmbonnamy@aol.com and I live in France
My unit, a 365i combo, uses the same transducer, I experienced the exact same problem last week, my unit is still under warranty, I sent the unit for repair and just got confirmation that my transducer went bad. The bad news is that the transducer is back order and has been for many weeks, this is an indication of probably a weak design. I have read similar reports on other forums.
Good luck
Posted on Sep 03, 2010
Testimonial: "Very fast and interesting answers tomy inquiries.Many thyanks to the contributors"
Hi we measured 12 meters long by half meter width how much is that in cubic meter
thats 6 meters square need another factor[HEIGHT ] for cube 12x .5x ?=CUBIC
Jul 17, 2016 | Garden
Haw do i calibrate metller toledo mp220 ph metter
1ST YOUR GONNA NEED BUFFERS:
All pH meters require calibration standards to ensure that the readings are traceable to a standard. Always choose a pH 7 buffer plus at least one other pH value close to your expected measurement range. Using solutions of known pH value allow you to adjust the system to read accurate measurements. Calibration should be performed before each reading or each set of readings.
After that this model has auto buffer select and it will tell You what buffer you put it in , also will ask if you want to correct it as well
Dec 05, 2014 | Measuring Tools & Sensors
Blew a fuse that operates radio, clock and all the electronics adapters, need to know which fuse works these?
My access to Suzuki diagrams does not indicate the functions of the fuses, it only gives me what they look like. Best thing to do is to have a meter to test the fuses and relays and whichever one tests bad, take that to the auto parts store to match it up. Most auto parts store will order you the correct fuse/relay if they do not have it in stock.
Jan 05, 2012 | 2003 Suzuki XL-7
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
How can i view the meter read on a E Studio 50F fax machine?
Press
Function
7
monitor key slowly 4 times
* star key
set
set
stop
Function 64
set
print
counts will be on right side of page.
Jan 07, 2010 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Speed ometer in the dash gives inaccurate reading while the digital reading in the widnshield appears to be correct. Fuel gauge has rapped around forward and temperature guage is off.
The problem here is your "Stepper Motors" are failing in the Instrument Cluster. If your Vehicle has "LOW MILEAGE" it may still be covered under factory warranty. Check with your Dealer first! If not covered under warranty, most reputable Speedometer Repair facilities can service it for you. All "Stepper Motors" in the Instrument Cluster should be replaced at the same time as the OEM versions are prone to ultimate failure.Typically, there are 5 or 6 dependent upon whether or not you have a Tachometer. They are: Speedometer, Temperature, Oil Pressure, Fuel Gauge, Volt Meter and Tachometer. The replacement part must have X25 168 where the X indicates an improved model.
Dec 12, 2009 | 2004 Buick LeSabre
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Humminbird XNT Transducers XNT 9 20 T  Mounting Unit Logo
149 people viewed this question
Top Humminbird GPS Experts
Jerry Greenberg
Jerry Greenberg
Steve
Steve
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
