Question about Microsoft Xbox 360 Console
Hi there, I have a problem with my xbox 360 hard drive. It says that error E 86 or 68. I'm trying to find their number, but it says nothing, I'm just a kid so try not to get a little angry. Also thank you if get this.
    Scholar:
  • 120 Answers
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
Posted on Sep 01, 2010
Error 40a3-0000-3080-0502-8007-045d
I got this from the Xbox support site for your error code.
Error Code xxxx-xxxx-xxxx-xxxx-8007-045D
A storage device (such as a memory unit or hard drive) was not found during the software update. Follow these steps:
  1. Turn off your console.
  2. Remove all console storage devices, including any USB flash drives, external hard drives or the internal hard drive on the Xbox 360 E console or Xbox 360 S console. Learn how to remove the hard drive.
  3. Add your primary storage device, for example, the hard drive.
  4. Turn on the console
  5. Try updating the console again.
Here's the website if you wish to peruse it further.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Post back how it works out!
Jan 06, 2014 | Microsoft Xbox 360 Console
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
My xbox 360 was saying error e74 now it will just turn on but screen is blank.pls help me
Nov 15, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
1 red light on xbox 369
hi, here follows a possible solution from Microsoft support:
One light on the ring of light around the power button on your Xbox 360 console flashes red.
You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
c. Press the release button on the hard disk, and then lift the hard disk from the console.
d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
Jul 31, 2010 | Microsoft Xbox 360 Console
Bottom right corner red flashing light error e 74
From the Xbox website sounds like you have a HDD failure / issue.
Try the following steps to resolve the problem: 1. Turn off your Xbox 360 console. 2. Removethe Hard Drive. For more information about how to attach or remove theXbox 360 Hard Drive, click the following article number to view thearticle in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/ ) How to attach or remove your Xbox 360 Hard Drive 3. Reattach the Hard Drive. 4. Turn on your Xbox 360 console.Ifyou continue to experience this problem, obtain the latest automaticupdate for your Xbox 360 console. To do this, follow these steps: 1. Turn off your Xbox 360 console. 2. Detach the Hard Drive. 3. Connect the console to the Internet through an Ethernet cable.Notes • Toobtain an automatic update without your Xbox 360 Hard Drive attached,you must have an Xbox 360 Memory Unit or an Xbox 360 that has built-inmemory. • If you cannot connect to Xbox LIVE, running a recent game (2007 or newer) causes an automatic update to be installed. • You can also obtain the latest Xbox 360 system software from the following Xbox Support Web site: http://www.xbox.com/support/ (http://www.xbox.com/support/) If applying the latest automatic update does not resolve the problem,please contact Xbox Customer Service. If the Customer Service agentcannot help you resolve the issue, you may have to replace the HardDrive. Discuss your replacement options with the agent.
For moreinformation about how to contact Xbox Customer Support, or to submit arepair request, please visit the following Xbox Support Web site: http://www.xbox.com/support/
Jul 25, 2009 | Microsoft Xbox 360 Console
Faulty xbox 360 drive
Have you tried your hard drive on another 360 as i think the problem may be with the xbox? If it works then send in your xbox to microsoft. 08005871102 is the number
Jan 17, 2009 | Microsoft 20GB Hard Drive for Xbox 360
Xbox 360 elite 1 red light
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
Microsoft Xbox 360 Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
