Question about Marc Refrigeration Refrigerators
I NEED THE PHONE # TO CONTACT A REPRESENTATIVE
Lost my phone can I receive replacement
Contact a TracFone service representative. Dial 1-800-867-7183 to report your SafeLink lost or stolen. Inform the representative of the estimated last date of use. Give a detailed description of where you may have lost the phone or how it got stolen.
  • Provide the representative with your mobile device's serial number or ESN found on your activation card. If you cannot locate the activation card, provide the representative with the cell phone number.
  • Request to keep your old phone number or apply for a new one. After the representative reports your cell phone lost or stolen, request that a copy of the report be sent to your active email address. Check your email address to make sure that you have received the email and a cell phone replacement confirmation number.
  • Expect the replacement SafeLink TracFone mobile device to be mailed to you within three to five business days, without cost. Check the contents upon arrival to make sure that the replacement cell phone, battery, charger, SIM card and activation card are intact.
  • To activate, call the number provided on your activation card. Provide the serial number, found on the activation card, and the SIM card code, found on the back of the SIM, to complete the activation process.
  • How to Replace SafeLink TracFone eHow
    May 06, 2016 | safelinkwireless.com
    Need puk code cincinnati bell i wireless motrola
    Instructions
      • Contact Cincinnati Bell Wireless customer service from another phone by dialing 1-888-391-3925. Ask to speak with a customer-service representative.
      • 2 Inform the representative you need to switch service providers and need the correct code to unlock your phone from the network. You do not need to specify a reason. Keep in mind that Cincinnati Bell does not have to release the code, but generally, if you are moving to another location not covered by Cincinnati Bell, the company will release the code.
      • 3 Give the representative the make and model of your phone, along with the IMEI (International Mobile Equipment Identity) number. You can obtain your IMEI number by pressing #06#. The representative will retrieve and divulge the unlock code.
      • 4 Put the SIM card from your new provider into your phone and turn it on. The screen will automatically ask for the unlock code. Input the code to unlock it, and your can begin using the phone.
    Courtesy: How to Unlock a Cincinnati Bell Wireless Phone ' eHow.com http://www.ehow.com/how_7652326_unlock-cincinnati-bell-wireless-phone.html#ixzz1jmmG9z4v
    Jan 18, 2012 | Motorola Lands Phones
    Need to change cell number my x boyfriend keeps calling my phone need a new number quick
    The only way to do this is to contact your cell phone provider. You can do this by going to the store or calling there tech support. There is no way for you to do this without speaking with a representative.
    You can have his number blocked too. You have to speak with a representative to do that too, though.
    Hope this helps! Please rate my solution!
    - Frankie
    May 06, 2011 | Sanyo Cell Phones
    My tracfone have a sim blocked
    Follow these simple steps
    1 - Input the code *#06# into your phone's keypad. Press the "SEND" button. Listen for the IMEI number, which you will need to provide to receive an unlock code.
    2 - Contact your Tracfone cell phone provider. Ask the representative for an unlock code. Give the representative your phone's IMEI number, model number and manufacturer's name.
    3 - Turn over your Tracfone. Remove the protective cover. Take out the battery and place the SIM card underneath. Replace the battery and protective cover.
    4 - Input the unlock code as provided by your cell phone provider. Press the "OK" button. Your Tracfone should allow you to access the network.
    thanks.
    Apr 19, 2011 | LG TracFone 600 Cell Phone - TF600GP4
    What is a tracfone sim blocked because MY PHONE SAID IT
    Jan 25, 2011 | LG TracFone 600 Cell Phone - TF600GP4
    I need to block a mobile number.
    Wlcome to FixYa
    Do Following:
    • Determine the number that you wish to block. If it's a harassing call, write down the number that appears on your caller ID. If the number is coming from an automated system, you may need to call the owner of the institution responsible for the calls, and have it corrected.
    • Call your cellular provider's Customer service department. This phone number can be found on the provider's website.
    • Avoid the automated system by continually pressing zero. With a representative on the phone, identify yourself, your account, your phone number and provide any password information if instructed. Explain your request to the representative, emphasizing the speed with which you need your request filled. Offer your phone number and the phone number you wish to block on your account. Obtain the representative's name, title and extension.
    • Contact your cellular provider's technical support department immediately after speaking with the customer service representative. This number can also be found on the provider's website. While a customer service representative may have already handled the problem, technical support can verify its completion. Provide the customer service representative's pertinent information to clarify and expedite the tech support's search. Ask if your request has been handled, technically-speaking. Obtain the tech support representative's name, title and extension.
    • Wait 24 to 48 hours. If the phone calls continue from the blocked number, contact customer service. Immediately ask to speak with a supervisor or manager. Explain to the superior your unresolved issue, provide the names and extensions of the previous representatives, and wait on the line until the number is successfully blocked. Again, ask to be transferred to technical support to verify the correction. If the problem continues, repeat until it is resolved.
    So you need Assistance of Network Provider to Block...Hope you got an Idea...If this Helped you-Vote Me..Thanks for Contacting FixYa....
    Jun 23, 2010 | HP iPAQ 510 Voice Messenger Smartphone
    I need a puk code for a sony ericsson f305
    To unlock the SIM card you will need a PUK (Pin Unlock Key) code that can only be obtained by a Customer Service representative. Do NOT attempt to enter this code unless directed to do so by a representative. Entering the incorrect PUK code more than 10 times will cause permanent damage to the SIM card.
    Contact your carrier and they will be able to help you.
    Hope this helped.
    Nov 18, 2009 | Sony Ericsson F305 White +512MB Unlocked...
    I removed Norton from my computer last December because of the intolerable length of time it used. Today I received my Bank statement which showed that I have been charged $40.16 Annual Renewal. I did not...
    Contact Symantec by phone. To do this you need to create a support ticket before contacting Symantec. During the creation of the ticket you can choose if you want to call Symantec, or if they will call you. To create the ticket, go here:
    http://www.symantec.com/norton/support/contact/contact.jsp?pvid=cs&id=ctcs1
    Then click the link with the text, "Click here to call us." Afterward you can set up your support ticket. Just make sure that in the field labeled, "We can help you with one of the following:" you select, "Norton product subscriptions."
    Once you get on the line with a representative you will need to provide proof of purchase (order form), probably your home phone number, and your mailing address. Afterward the representative will continue down the road of awarding you the refund.
    Feb 20, 2009 | Symantec Norton AntiVirus 2008: Windows
    I9 phone
    I had that problem for a while, just turn your phone off, ait about 10-15 mins. then turn it back on and if it's not working then you need to contact a representative..
    Contact me:
    onleadyace@hotmail.com
    Dec 25, 2008 | Dual Electronics CECT P168 Cellular Phone
    Bought a used cell phone/ LG 285 Teus mobility/ need to reset
    it would be best to contact your mobile service provider customer service representative for more assistance.
    Dec 01, 2008 | LG Secret ? KF750 Cellular Phone
    Refrigerators Logo
    16 people viewed this question
    Top Marc Refrigeration Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Marc Refrigeration Refrigerator Expert? Answer questions, earn points and help others
