Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
I'm getting lines and mosaics on the video tape output of my Sony DCR-HC40, and a message on the viewing screen to use a head cleaning cassette. After a minute or so the lines go away and the video is fine. I've never used a head cleaning cassette. Are they any good? When I used to clean the heads on my VHS VCR I used an aerosol spray-on head cleaning solution with a long narrow tube to direct the spray. The kit came with foam tipped cleaning swabs that could be saturated with solution and used to physically clean the heads if the direct spray was not enough. What do you suggest?
    Scholar:
  • 95 Answers
NEVER try and manually clean your heads in your camcorder. The drum assy and heads are much more fragile and easily damaged than that of a VCR. NEVER spray any type of liquid/chemicals in or on your camcorder. A Sony miniDV head cleaning cassette is what you need. There are other brands out there, but Sony is hands-down the best. When using a head cleaner, play it for only 5 to 10 seconds at a time and then try your tape again. If it has improved, but still has problems then play the head cleaner for another 5 to 10 seconds. Hope this has helped. www.austintelstarservices.com
Posted on Sep 02, 2010
DCR-HC40E camcorder error C:31:30 message. can you help?
reset the camcorder. (open the tape deck and you'll see a small hole that says reset on it) press and hold the button inside the hole for 3 secs. then also clean the tape head(the metal thing that reads the tape. with a q tip.
Sep 06, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony DCR-hc42 video camera problems
Buy a Sony-make head cleaning cassette and play it in the camera for 10 seconds. Do not play for more time, neither forward or reverse the cleaning cassette, otherwise you will damage the head of the camera. This cleaning cassette is to be thrown when it is fully played (and not rewound!).
Nov 30, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
I have a sony handycam - dcr-pc109e. When viewing a tape, there are grey horizontal bars across th screen that have just appeared. I cannot seem to get rid of them. Any ideas please?
Gray horizontal lines appears when video heads in camera got dirty / clogged.
Use good quality video cleaner cassette to clean video heads, problem will resolve.
Dec 16, 2008 | Cameras
I have sony dcr-hc40
Put the camera in VCR mode not camera mode. Then play the cleaning tape. That should do it.
Dan
Jun 25, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Dcr-hc40 dropped and tape door won't close
try and take the door off and straighten the cassette holder assy
Sep 14, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Gray bars across the screen...
try to clean the video head using a blank new tape just forward it 5 times as need...do not use video cassette cleaner cause it too rough for the head....check the head if there no crack on it....if nothing you find it is time to replace the to the service center...
Jul 27, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
424 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
