Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Scraches on outside of refrigerator door - KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
  • 944 Answers
Hi this link could help out
How to remove scratches in refrigerator click here
http://www.fixya.com/support/r5829593-remove_scratches_outside_refrigerator
Posted on Sep 01, 2010
How to fix scratchs on stainless door of refrig.
If you are in Canada go to www.reliableparts.ca or if you are in USA go to www.repairclinic.com and ask for "Scrach be gone" treatment kit
Jul 31, 2014 | Sub-Zero 690 Side by Side Refrigerator
Condensation on outside of freezer door.
maybe your freezer door slight a bit open or have a gap causing the cooled air from the inside mixed with the hot air outside.
Feb 24, 2014 | GE Monogram Side by Side Refrigerator
Refrigerator not cold
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
Jan 04, 2014 | GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY...
Frig is very hot on the outside ban that meets the seal
That heat that you feel is part of the design of all refrigerators. Those heaters are there to keep water from condensing on the outside of the cabinet around the freezer door. Just like water condenses on a cup of Ice water. It will do the same on a refrigerator. If those small heaters were not there. The water would cause the paint to rust badly. There are various arrangements of heaters used on Freezers and refrigerators around the doors. Particularly the Freezer door.
As long as the fridge is cooling properly it is fine.
If the fridge fails to get cold, the outside of the cabinet will actually get quite hot.
Hope this helps,
Best, Mark
Dec 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
When the light outside on the left door is on
If it is not affecting operation (cooling) then it is probably annoying vibration. Nothing to worry about.
Mar 25, 2010 | Hotpoint HSS25GFP Side by Side...
My Daewoo FR370 DLX two door rerfigerator sweats in the outside edge of the door. Has the door seal got worn off. It is five years since I bought this refrigerator. Kindly assist me
yes, the sweating is from the temp difference from the inside and outside of the door. The air must be escaping past the seal.
Nov 25, 2009 | Refrigerators
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Moisture standing on outside freezer door. HTS18
Look inside the refrigerator section for a switch that says high moisture or energy saver . Some units allow the door frame heaters to be turned off during times of the year when the humidity is low.
Sep 21, 2009 | Hotpoint HTS18 Top Freezer Refrigerator
Outside of fridge door turns brown in color with high humidity
Check your door seals or for cracks in plastic shelves. Sounds like condensation getting to metal causing rust.
Jul 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
62 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
