Question about Samsung V70 Digital Camera
My camera takes pictures which look fine on the monitor, but the captured image is covered with horizontal jagged lines. Any ideas what may be occuring .... help please?
  • Samsung Master
  • 17,130 Answers
It is an error in the camera as the picture/image caught into the memorry is having some noise when reproduced.
remove the battery for some time (10 min) and put it back without the memory , then after some time remove battery and insert the memory. Iff possible put the camera on charge for some hours .Also put the camera on continuosuly . check if the fault has changed, if so some capacitor is weak and on charge gets rectified.
Posted on Sep 01, 2010
Lines in pictures
There are two common faults for this problem. 1 is shutter failure and the other is sensor failure. To determine which is simple. For shutter failure put the camera in full optical zoom. Turn off the flash and look through the lens and take a picture. You should see the shutter completely cover the lens inside. Any gaps will result in over exposed pictures or horizontal lines. the other is video mode. if the problem is apparent in video mode too then sensor failure is the likely problem.
Aug 24, 2012 | Sony Cyber-shot DSCS2100 Digital Camera
The pictures have horizontal lines
This is electronic shutter problem that is the reason you get blinder effect/ noise on picture. Electronic shutter is located in lens mechanism and lens assembly will be replaced to solve the issue. Nearest Samsung service center or local camera repair shop will help you to replace lens assembly.
Thanks.
Aug 03, 2010 | Samsung S630 Digital Camera
When I take a picture it looks fine on the screen. When I then review my pictures there are red lines going through the picture.
The problem is due to CCD/CMOS (the chip that physically captures light and creates the digital image) has broken. If this is the case , a repair would cost approximately $80-$130. This is the most common problem for a camera that takes blank/lines in images but where the menu display functions and old photo's display normally.Please confirm that these stripes are normally behind the menu's. Check to see if the new images are downloaded correctly and if the video function works normally. If this does not work, it supports the idea that the chip has gone.Take it to a repair,if the CCD has to be replaced then a new or refurbished camera would cost only slightly more.
Thank you !!
Jun 21, 2010 | Kodak EasyShare M853 Digital Camera
When I take a picture,it does not appear anything.
when I take a picture, the only thing I see in the image are horizontal lines and no picture.video camera is working fine.
Jun 06, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
When turning on the camera to take a picture, many times there are horizontal lines in the view finder. Taking a picture captures these lines, not the image
The imagery board need to be replaced, The camera has been dropped. I had the same problem with mine. Send it back to Fuji they will repart it but they will charge labor.
Nov 20, 2009 | Fuji FinePix S5000 Digital Camera
Hi, I seem to have a problem with my Finepix Z1 digital camera. When I take a shot it seems to work ok, and the initial review image seems fine as well. But when I go back and review the image on the...
The clue is with the video.
The video function does not use the shutter. Lines on photo's or over exposure is due to the shutter not closing completely over the lens when you take a picture.
It will require cleaning which means opening up your camera and accessing the lens unit
Oct 28, 2009 | Fuji FinePix Z1 Digital Camera
Horizontal lines on Canon A410 images
This sounds like a 'stuck shutter'. Especially if it does not make the faint clicking noise when taking a picture anymore.
Try the solution on the following page at your own risk.
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Sep 02, 2009 | Canon PowerShot A410 Digital Camera
I take the picture and the whole image has lines through
If it has the lines for EVERY picture, that normally means your imager has gone bad...
Jul 07, 2009 | Casio Exilim EX-Z55 Digital Camera
Horizontal lines in pictures
this a CCD failure !! but u are LUCKY enuff
u can get it repaired free of charge it is a manufac fault many face it
see ur self
http://www.imaging-resource.com/badccds.html
see the link dont worry if ur model is not incl in the letter they will do it free of charge just give them a call and pls rate me FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
for asia
http://support-asia.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
Feb 22, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
CASIO EXILIM digital camera photo resolution
The Digimax A7 Doesn't work outdoors, because on top of the camera, try taking a picture, but hold your hand on the top of your camera (Cover it) it's light sensitive. On top their is a built in sensor, the Darker it is the darker the picture is, the lighter, the lighter. If you cover it, (Usually on top) It should work fine outdoor, just don' t cover it indoor. Hope this helped. -CA
Jul 14, 2008 | Samsung Digimax A7 Digital Camera
Samsung V70 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
