Question about Amcor ALTL-12000E Portable Air Conditioner
I bought an amcor 12,000 BTU portable AC two years ago. I used it for a month, never used it last year, and then tried to use it yesterday and it is dead. As in, there's no response when I push any buttons. I have tried the reset button. Green light is illuminated but it acts as though it has no power. Any thoughts?
  • Amcor Master
  • 17,130 Answers
When a sett is kep unused for sometime the possibility of faults can vary as when it is in regular use.The best way for a first hand info is to trace the line of power fromthe controller unit to the compressor.Check the line to the compressor, if the control panel is faulty, check compressor relay, check capacitor.
Since it is failure of power, it can also be a wire break.
Posted on Sep 01, 2010
I have an Amcor Portable Ac 12000 BTU and it keeps shuttig off due to condesation. I drain the unit ;but it only lasts for about 20 mins of run time before it shuts off again.Whats wrong with this?
Unit is not draining properly and only works when there is no condensate in the pan. The latter could have a clogged drain hole - check for that and clear if applicable.
Aug 19, 2015 | Amcor Heating & Cooling
Where in Southern California can I get it recharged with freon?
Generally portable a/c units are not recharged because they do not contain a service port like a home or auto a/c unit does. At the factory they charge the unit crimp the tube then weld it closed. And no one can service freon unless then can vacuum recover it.
Aug 05, 2015 | Amcor NanoMax 12,000 BTU NanoMist Portable...
Amcor portable Air conditioner replacement exhaust hose
I am also looking for a replacement hose for my amcor nanomax portable ac 12000 btu. If I locate one, I will let you know
Jun 26, 2013 | Amcor Heating & Cooling
9,000 btu invertor system & 12,000 btu system dripping water from evaporator case,evaporator very clean,suction line not freezing up,just sweating as it should,condensor fan running good,is there a...
The condensate line attaches to the back of the indoor unit. Usually the flex drain line that comes with the unit clogs with algae. You've got to remove the line and flush it with compressed air or nitrogen and then pour about a cup of clorox bleach down the line to inhibit further growth. Use the clorox twice a year to prevent this from happening again.
Aug 10, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Looking 4 a minisplit - heating & cooling - 12,000 btu 16-20 SEER
I have been doing this for 45 years and for the price the Amcor is the best because they send you everything you need to install unit. I just installed one for my neighbor18,000btus He paid 1000 included shipping. The tech support is great. Russ
Jul 25, 2009 | Heating & Cooling
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Portable Air Conditioning unit no longer blows out cold air
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Jul 01, 2009 | Heating & Cooling
Amcor ALTL-12000E Portable Air Conditioner Logo
217 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
