Question about Foxconn 661FX7MF-S Motherboard
Problems with windows.
I am having multiple problems. First I connected the montherboard and everything on it and booted it and it could not install windows XP, it said can't read hard drive. So I installed the hard drive on to another computer and install windows that way, and even install a couple games. Everything worked great. Then I take the hard drive and put it back into the 661FX7MJ and then I started getting problems again. When I can get it to start windows and then tries to install the new device drivers, when I restart to install it doesn't start windows anymore and have to try couple times again to get it to start. Then I have the same problem and it tries to install drivers. Sometimes it doesn't read the hard drive at all. What should I do? I feel I have tried it all. I put windows XP CD and boot off that but it seems to get issues with that also.
  • The1msT May 11, 2008
    I have a PATA hard drive installed, and I tried what you suggested. I switched the cables with the cd roms and it started loading windows, but it took a really long times. Once it loaded it worked fine, drivers would begin to install and when it rebooted it worked. But then I thought the computer was working and continued installing the rest of the drivers like directX and when it finished it restarted and same problem. It would go up to windows loading and then reboot. I tried reformating it but sometimes it doesn't read hard drive or it will freeze while partitioning. Could it be the motherboard? since its new, I'm not sure what it might be.
Are you using a 40 lead cable or a 80 pin, you should have 80 for the harddrive and 40 for the cdrom, so they are not interchangable, and you have to have 80 for th eharddrive
IE 40 and 80 both have 40 pins, but 80 has twice as many wires in the cable
Posted on May 12, 2008
  • 1,027 Answers
  1. Are you using a SATA drive or an IDE(PATA)?
  2. If using SATA, is SATA set up in bios as first boot or second after CDROM?
  3. If using PATA hard drive is the IDE channel working properly? Switch the CDROM and Hard drive ribbon cables on the motherboard.
Posted on May 10, 2008
  • Mark Williams
    Mark Williams May 11, 2008
    Sounds like the chip set controller on the board is corrupt. When that happens and you can not update chip set firmware then it is time for a new board.
    I bought a Refurb board from the and when it arrived the primary IDE channel was INOP so I installed SATA hard drive set bios to boot that way and everything was fine, didn't want to bother with an RMA and return it.(I had an anxious customer). Sorry I couldn't give you a "FIX"
Missing NTLDR file.
To repair missing orcorrupted system file/s, please click on this link and follow my instructions :-
May 22, 2011 | ASUS P5GZ-MX Motherboard
I have a problem! I instal the windows and i don't know the name of my video card, the video card is integrate in montherboard. The montherboard name is Micro-star MS 7211!Please help me, and i'm sorry for...
Here You can find all drivers to your motherboard:
There is a 4 in 1 which includes video drivers - but there is also some other which I can recommend you to install to get sound and so on working correctly.
Jan 23, 2011 | Computers & Internet
AMD Data Change - Update new data to DMI! PXE-E53 - No Boot Filename PXE-M0F - Exiting nVidia boot agent. what do I do?
I need a little more info on this. I assume your using windows 7? I have a couple of thoughts on possible problems. It sounds as if your Bios is ether corrupted or might be set to boot in the wrong order or your hard drive has failed. I do not know what your system is but when you first boot up you should see a comment (usually at bottom of screen) that tells you which key to press to access your Bios. I do not know how much experience you have with computers but you need to be careful in there because if you change the wrong setting you could cause problems within your system. So after accessing your Bios screen you should be able to check the order of your boot process. (I'm thinking you might have multiple hard drives or partitions?) If everything checks out there is a good possibility that your hard drive has failed. Good luck
Jan 05, 2011 | Acer Aspire X3200 PC Desktop
I installed Kaspersky 2011 and no problems until yesterday. Now it will not load and takes longer than usual at startup to even get to the desktop. The cursor moves, everything is extrememly slow and...
After hearing your computer beep once during startup, start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
Instead of Windows loading as normal, Windows Advanced Options menu. Choose safe mode with networking.
Go to control panel then add/remove programs and uninstall Kaspersky Internet Security from there.
If you want an automated removal, you can donwload the kaspersky remover from here.
You can aslo visit this website for a guide.
hope this helps.
Nov 29, 2010 | Computers & Internet
Problems with windows essential messenger/mail
it feels like you are not reinstalling after a clean format or before clean format u can try clean boot in Windows 7
i am providing u link for more infomation on clean boot
hope this would solve ur problem
good day
May 29, 2010 | Computers & Internet
After installing new video card it takes a long
Without more info it's hard to say for sure but here's a few suggestions.
Turn your power completely off, unplug your computer, double check all your connections, memory, cards, cables, the works. Any loose connections can cause multiple rechecks.
Check your BIOS for quick memory test and set it to "yes" or "enable".
Look to see if you can skip some of the memory tests, if so, skip them, you don't need them unless your having problems.
Set your boot sequence to check only the drives you normally boot from. If you usually only boot from your hard drive set it to only check your hard drive, you can change it latter if you need to boot from a different drive, this is faster and more secure.
Turn off "floppy seek at boot" unless you use a floppy drive.
Turn off your serial ports if you don't use them.
If your computer has unused IDE controllers you can turn them off too.
Be sure to make notes of everything you turn off, it can be a real pain to trouble shoot a problem for something you turned off and forgot about.
May 24, 2010 | Biostar P4M900-M4 Motherboard
Multiple problems with vista
Since the step are fairly long I have supplied a link to a tutorial,Just Go here for the step by step details
Please rate this fixya
May 16, 2009 | Microsoft Windows Vista Ultimate Edition
Minimizing screens - multiple
Personally I think that Avast might be your best bet and it is free. Avast is like AVG, however from my experience I have seen Avast catch a lot of virues that AVG didnt catch. Also another thing that you need to do is run Spybot or any other spyware cleaner in Safe Mode, this way the viruses or spyware wont re-install themselves while you are running the scans. To download avast, just go to and download/install the home edition. Once you have downloaded and installed it, let it run a boot-time scan ( it will ask you this when you first install Avast ). Also you try other spyware cleaners such as adaware ( and/or Windows Defender ( BTW, if you decide to run AVG and Spybot in safe mode and dont know how to get into safe mode, do the following:
1. At boot-up, continually press F8 until a list comes up
2. Choose Safe Mode from the list
Let me know if this helps you out.
Serge C.
Mar 30, 2009 | Microsoft Windows XP Home Edition
Gateway 995 boot problems
Maybe you can check you BIOS / your boot device priority and set it to your hard drive as default.
If this doesn't work, then the problem would be your hard drive (it's read / write function is not functioning properly.)
Feb 21, 2009 | Gateway Computers & Internet
No boot, Intel Classic DG31PR, had been working ok
Do you get any beeps sounds when u start your computer? Try removing the memory card and insert it again or try another memory card slot.
Oct 12, 2008 | Intel DG31PR Motherboard
Foxconn 661FX7MF-S Motherboard Logo
165 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
