Question about Campbell Hausfeld PW2102 Gas Pressure Washer
I have a used pw2050 3le, fired it up and water shoots out between e head and pump body, my be missing parts ?? which ones t seems to have pressure???
5.7 misses and backfires at acceleration
Back fires have to do with valves. They could be sticking,bent, or carboned up. To check and clean carbon. Get the engine up to normal temperature. Rev it up and pour water into the throttle body/carburetor. Water will clean all the carbon build up off the valves and the top of the pistons. If this doesn't fix your back fires, Then your looking at a headjob. If you have really high miles on the vehicle, I would be looking for another one. Head jobs and high miles don't work out to well...
Oct 10, 2014 | 1997 Chevrolet Tahoe
Only shoots out one nail for every 4 or 5 trigger pulls
The gun will miss fire if the driver does not return to top position allowing nails to move into position. Could be bent driver, faulty trigger, cracked lower bumper or check valve not in place. Easy to check if trigger. Remove air supply, and remove the pin holding the trigger. Fire the nailer by depressing the firing pin with your finger. If the gun works ok, single fire trigger is faulty or safety foot is out of adjustment. If still miss fire, remove head and pull out cylinder and piston. Check for bent driver, cracked lower bumper or black band (check valve) is out of place on outer part of cylinder covering a row of holes.
Aug 23, 2011 | Porter Cable Cable Factory Reconditioned...
Miss firing you have to place it on an angle to get it to shoot
Dewalt has a new trigger valve to replace the original (part number 5140095-73). Not sure if the new valve is replacement to address an issue or natural progression. I would also replace the orings that make contact with the reference #55 on parts list called the bulkhead. There are four orings contacting the bulkhead that wear and may contribute to multi-fire or miss. Finally, look for worn parts that contact the trigger. The safety foot pushes up on the inner part of trigger then pushes on the firing valve pin. If safety mech parts are worn or trigger is worn, the gun may miss. Parts are at dewalt service center or at www.toolpartsdirect.com Good luck
Aug 09, 2011 | Dewalt Round Head Framing Nailer D51845
Transmisson won't shift out, runs hot and water shoots out of radiator,smokes,now won't start. seems like computer but not sure
not the computer you have engine problems ,head gasket blown , water pump , something in these area need start checking one by one.
Dec 13, 2010 | 2002 Pontiac Sunfire
Replaced everything under the sun on our 87 olds delta 88...wont fire on its own but will fire and run fine as long as u shoot it with starter fluid. We replaced starter, fuel pump, filter, plugs, wires,...
Can you here the fuel pump running?no, check fuse,and pump relay. Check pump fuel pressure,at the fuel injector rail,or throttle body. Check for voltage at the top wiring on the fuel nozzel.While cranking look for pulsating voltage.None, test computer,scan system. let me know the outcome.
Aug 30, 2010 | 1987 Oldsmobile Delta 88
Hitachi NR 83A2S, Nail wont fire properly
The NR83a has an adjustment just below the triggering plunger. It is a 6mm hex head bolt with a locking nut. Loosen the nut and adjust screw out several turns and re-test. Make adjustment as necessary. I have seen many of these gun without the locking nut which allows the bolt the adjust itself all the way down. AS parts wear this screw needs to be adjusted. The pushing lever and the plunger are wearing smaller/shorter, that is unless the locking nut was missing. Remove gun from air supply for safety when making adjustments. Good Luck an email if you have other qustion about this gun.
Apr 27, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Remove water pump have removed outer plastic blades of viscous fan and the four small bolts behind the water pump it seems loose but will not come away, is it just the internal impeller blades dont want to...
what's up led, the large viscous nut is loosened in the clockwise direction. after you remove the 4 nuts on the water pump, you should see one hole on each side of the water pump body. if you take 2 bolts out of the thermostat housing, you can use those to thread in the pump body holes.slowly tighten each bolt equally and the pump should come out. to install a new pump, lubricate the o-ring on the new pump and just push in by hand.
Mar 21, 2009 | 1996 BMW 318
Nail gun double fires
There is one main part that can be the cause of the problem.
The trigger. Check to see if there is anything out of the ordinary with this. There should be some moving components attached to the trigger itself. Is any part of the trigger touching the button in the body of the gun when safety is not depressed. If the lever on the trigger is pushing on the button, even a little bit, It will allow the gun to fire again and again.
Mar 12, 2009 | Air Tools & Compressors
Cheats splintercell.the game please.
Keypad codes Mission 1 - Police Station Keypad 1: 091772 Keypad 2: 5929 Mission 4 - CIA HQ Keypad 1: 7687 Keypad 2: 110598 Keypad 3: 2019 Keypad 4: 110700 Keypad 5: 0614 (if Dougherty gets through the door before you can) Mission 5 - Kalinatek Keypad 1: 97531 Keypad 2: 33575 Keypad 3: 1250 Mission 8 - Chinese Embassy, Part II Keypad 1: 1436 Keypad 2: 9753 Keypad 3: 1456 Keypad 4: 1834 Keypad 5: 7921 Mission 9 - Presidential Palace Keypad 1: 2126 Keypad 2: 70021 Keypad 3: 66768 Save ammunition If you find a room being patrolled by a guard or worker, wait until he leaves, then turn off the light switch. When he returns, he will immediately move to the light switch to turn it on. At this point, his back should be turned to you. Quietly sneak up and either grab or punch him without firing your weapon. Flares If you are pinned down by a turret, throw a flare across it. The turret will be distracted for a moment, which may be long enough for you to sneak behind it and disable it. Taking out two guards Shoot a sticky camera near the guard closest to you. When he approaches, use gas to knock him out. The other guard will approach to investigate. You must either shoot him with a non lethal round if you cannot have casualties, or take him out with a head shot if killing is sanctioned. This has to be done correctly or he will revive the guard that you knocked out. Eliminating guard threat without ammunition If you do not have ammunition and you find two guards, sneak up to one and take him hostage. Make sure that your hostage is facing the other guard or he will shoot you. If you do not have ammunition, hide in the shadows and wait for a guard to come up to you (or slowly creep up to him) then press R1 to punch him. Use two punches to knock out someone. If you need to knock out many guards without killing them, look around for a water puddle. Try to lure them into it, then shoot a Sticky Shocker into the water. This will knock many of them out. This works with any body of water, including the sewers in the Chinese Embassy level. Luring your enemy To do this, find a can or glass bottle to pick up. Once obtained, move to a location, preferably dark. While hidden, throw the can or bottle to an open area with an enemy nearby. When thrown, the enemy will wonder what happened and walk towards that location. After you have drawn him out, you can take him out for an easy kill. Hiding bodies After you have disposed of enemies in an area, make sure that you still hide them, even though no one is nearby. Before going to another checkpoint, the alarm may ring, and it will say that a body was found. Try to hide all bodies in hidden areas for best results. Quickly drop body When moving a body, equip your weapon. This will automatically drop the body. Hide face Have the diversionary camera equipped with the SC-10. Press L1 button before you zoom in and fire it at a wall. If Sam is close to the wall, he will put his hand in front of the camera to hide his face. You can try this with any sticky camera, but you need to be close to the wall you shoot it on for him to cover it. Rifle rapid-fire Equip the rifle and press L3. The bullets on the screen will be a bit darker. This indicates that you have switched to rapid-fire mode. Be careful, as you cannot simply hold the trigger as you could before; the gun will shoot as much until you release. Sniper mode: accuracy increase For better accuracy on sniper mode, hold L1. Note: This may take a few seconds to start. Escaping a room full of soldiers Take a sticky camera or smoke grenades and throw it near where the most guards are located. For the sticky camera, a control bar that tells you how to make a noise or use smoke will appear at the bottom of the screen. Throw the smoke grenade and the smoke should knock out some guards. When the smoke appears from the grenade(s), it is your chance to run for it. Knock out an enemy To knock out an enemy without killing him, equip the sticky camera and shoot it at his head. Aim slightly above the head to compensate for gravity. After he is down, pick up the sticky camera and use it again. You can also throw bottles to knock out guards. You must aim well and hit them in the head.
Aug 13, 2007 | Sony PlayStation 2 (PS2) Console
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
108 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
