Question about Dell 3100cn Laser Printer
I have error message 016-315 on my Dell 3100cn. Says to restart printer but nothing I have done works
SOURCE: Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Posted on Jul 11, 2008
Corysf62
  • 188 Answers
SOURCE: 010 397 Error Message on Dell 5100cn
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Posted on Oct 02, 2008
SOURCE: Error 016-302 on Dell 3100cn
drum cartridge replace soon
Posted on Oct 30, 2008
SOURCE: Error 003-343 Dell 3110cn
Open the printer using the button on the side top right. You will see two gray things with arrows going left and right. move them both two where you can take out the piece it is hold in. Pull out the large piece and put it back in. Close the two gray things to lock it back into place. Close the printer and restart it. It should fix your issue. It must of became loose at one point when I was moving so I fiddled with it and turns out that was the issue. It works great now!!
Posted on Nov 09, 2008
SOURCE: RESTART Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Posted on May 18, 2009
I'm getting the following error: Dell 3100cn Laser Printer error 004 332 problems
Try restarting your printer, if this does not help make sure that the toner cartridges are set in properly and locked in place.
Mar 28, 2011 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
004321 restart printer error
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Nov 30, 2010 | Dell 3100cn Laser Printer
Get error message "004-321 Restart printer" Have tried everything.
this is a 'reseat drum' message. If you do that and make sure all is clean then restart it should be fine.
Sep 12, 2010 | Dell 3100cn Laser Printer
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
We are getting error code 004-332 Restart Printer on our Dell 3100cn printer. We have tried unplugging and restarting print spooler but it still come up witht message when we try to print
Hi
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Daniel Scott
Jun 24, 2010 | Dell 3100cn Laser Printer
Dell printer
Error code: 004-332
Aug 26, 2008 | Dell 3100cn Laser Printer
My Dell 3100cn will not print unless I press Init NVRAM and restart printer every time I want to print. This is annoying. Can you help? Thanks! Greg
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
rate my answer
Aug 22, 2008 | Dell 3100cn Laser Printer
Dell 3100CN Error Message
I am a publisher here in Seattle printing full color books with this machine and I have just gotten the same message- Does anyone have a solution- I have Googled and checked everything... Now, this happened to me a few months ago and I pulled out the drum and sprayed it with air, replaced it and it worked fine for about two months- now I get the error again- does this help in the problem solving?
Jul 01, 2006 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
330 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
